Can I use a 4wd 4l80e
I can get my hands on a 4l80E with 30,000 miles on it dirt cheap out of a Silverado, problem is the truck has 4WD.
What has to be done to use this tranny in a F-body.
Marco
Marco
You will also have to add a reluctor to the rear carrier in the transmission when it is apart because the 4x4 unit uses a sensor on the transfer case and doesn't have one in the trans for the output sensor !!!!
Originally Posted by Krazy98Z28
is it too much of a pain in the *** or should i stick with it...although i'm leaning more towards a th-400 right now
-Dustin-
