LS7 clutch review
LS7 clutch review
Mods are in sig, made 373 and 370 at the wheels. And I love this clutch. The relase point has already come up after only 250ish miles. Grabs like hell and the is just amazingly easy to push in. Would def recommend this clutch.. cant beat the price either
Sounds good, where's a good place to buy both the ls7 clutch and ls2 flywheel?
Pedal effort feels just like stock, not a problem at all bud. And the best place to buy them from is one of the sponsors scoggin dicky... $400 for clutch, pressure plate and flywheel!
LS1TECH & Trucks Sponsor
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
No shim, and I don't think you will beable to get it local. The guy who did the work on my car has a great connection at a local dealership and his guy price matched matt, but couldn't believe that he can sell it at that price... My advice, just get it from SDPC, thats what I was gonna do until my bud was able to get it. BTW i've talked to matt a couple of times about other things and he is a great guy to deal with.
LS7 is the clutch to go with. Only a few problems ive had which are kinda my fault. the Ls7 clutch dosnt seem to like track duty like the LS6 did, you deffinently need to let it cool down a bit. Also one time I downshifted messin around with some audi and spun the hell out of the clutch But I would give the clutch a 10 out of 10, very affordable and will handle any respectable ls1 power
I was thinking about trying an LS7 when i replace my 3+ soon. I let some girl drive my car one night when i was wasted and she broke my 3+ cause she couldnt drive it right. It still drives but it slips sometimes, so i need a new clutch now.
I just doubt the LS7 will stand up to 700 ft lbs though.
Note to self- Dont take the trans am out when you plan on getting wasted.
Dually noted! LOL sorry to hear about that bud, and I am pretty sure that it won't either. You gonna go with a tex then?!?
Internet Mechanic
On the LS7 clutch mine still lives after a year of beating on it & my H/C install. So I'm also very happy with it. Not to mention the ease of install.
Originally Posted by BIG_MIKE2005
With your mods & power level I wouldn't even look at the LS7 clutch. I'd do a McCloud twin disc & be done with it. It's pricey, but it'll take your abuse & ask for more.
Hey bud, how many miles have you put on your setup? How many track passes do you have? Thanks alot
NO SHIM.
I have seen this asked WAY too many times on here. I'm not pickin on you specifically so don't take this as a direct insult.
This clutch is a DRIECT BOLT-ON replacement/upgrade. This means no shims & it will work perfectly fine with all stock bolts & hydrolics.
68birdls1: I have had it in for about a year. Several track passes including a couple hot laps. Never had a issue & I have cut a 1.9 60' on it without it slipping. Though it is important to note I only run on street tires b/c of my 10-bolt.
The clutch itself probably has about 15k on it since installed & 5k on the H/C install. Still lights them up @ 40mph in third on a good clutch dump too.
hmmm....ok. valvegod on here is who I bought the clutch off of and he said he installs the shim on every ls7 he does. just getting mixed oppinions here. oh well, I guess its a win win........
Every person that I have talked to about the LS7 clutch said not to shim it. It has a self adjusting system, the pedal will come up off of the floor after x-amount of miles. Just do as the instructions say and you will be fine.
