Changing cam
Old 08-24-2007, 05:24 PM
therobman's Avatar
Default Changing cam
i have a tr224 112 what other cams can give me a lil more power but still keep driveability????????
Old 08-24-2007, 06:14 PM
68birdls1's Avatar
Yea, but I would look elsewhere in your motor to modify, like the heads. That is if you all ready have the cam in, if you don't then you could look at something like what I have in my sig. Great cam, awesome power and drives excellent.
Old 08-24-2007, 06:24 PM
therobman's Avatar
cams not in yet so im lookin for a bigger cam i was thinkin maybe tsp 233/239 how would that do over the tr224 and what about drivability
Old 08-24-2007, 06:31 PM
Dragkid1917's Avatar
haha i posted on your other comment on another link, that u should get a bigger cam then the 224. I have like, exactly the same setup as you, cept i run a LM1, and my stuffs not polished and my stall is 3600. Im goin with the 233/239 and it should be in by next weekend. If you wanto wait i can tell you how it goes, i figure u can get a 114 lsa to smooth out the idle, and if u want just advance the cam 2 degrees to lower the power band if thats whats for you. im doin 112lsa and installing it at 0. It should haul ***.
Old 08-24-2007, 07:07 PM
therobman's Avatar
yea i would deff get the 112 one let me know how it goes and what number u throw down
Old 08-24-2007, 07:18 PM
therobman's Avatar
any other suggestions?????????
Old 08-24-2007, 07:28 PM
gts500's Avatar
the 224 is verey nice option if drivebilty is what you lookin for, i had that cam before and to be honest i regret swaping to bigger choise. the 233-239 will produce more power but only at the peak of your rpm wich is where you will shift gears? the only thing i got from swaping to bigger option is dyno number but on the street the small duration cams rules, the TR224 has a verey strong power band on the low end and mid high.
if you want somthin simillar to the TR224 but slight bigger and daily driver cam,i suggest the 228R from TSP. but remember the more bigger the late power band you get,on the streets you need to be fast to get to the power band quickly, not to chase somebody on the middle of the race,its irretating trust me .
good luck
Old 08-24-2007, 07:37 PM
therobman's Avatar
good point im trying to decide the perfect cam before i put it in
Old 08-24-2007, 07:46 PM
gts500's Avatar
TR224 or TSP 228R 112 ,you will never regret .
Old 08-24-2007, 08:06 PM
therobman's Avatar
hahaha thanks man i got the tr224 112 sitting next to me just seeing if its the right choice
Old 08-24-2007, 08:14 PM
00 Freak's Avatar
I would go with some heads. Get a set of ls6 heads ported and milled or 5.3l ported and milled.
Old 08-24-2007, 08:23 PM
therobman's Avatar
if i keep the tr224 im either gunna get 5.3L Stage 2.5 CNC Ported or PRC LS6 CNC Ported Heads
Old 08-24-2007, 08:47 PM
00 Freak's Avatar
I've seen a few go with the 5.3l heads ported and milled and make 400+ rwhp on a auto. TSP only charges $75 to mill them. It would be worth it. It'll bring more compression which means more hp.
Old 08-24-2007, 11:38 PM
therobman's Avatar
still tryin to decide what i should do anyone else?
Old 08-25-2007, 12:24 AM
bsf
bsf's Avatar
You probably realize this, but I will mention it anyway. Tuning is going to have a huge effect on drivability. I have a 226/230 111lsa + 2 and drivability is not great w/ my mail order tune.
Hopefully that will be addressed shortly, though.
Old 08-25-2007, 07:22 AM
gts500's Avatar
if you goin to do heads, stick with small runners like 205c and closed chamber like 62cc or 59cc .
if you go big runner like 225 you will have your power band at the peak as mentioned. so installing a good head combo matching your cam will pump up HP like crazy specialy power under the curve thats everyone is lookin for.
Its gonna be a kick *** ride
Old 08-25-2007, 08:38 AM
85ta383's Avatar
had a 230 236 custom cam.. and swapped it out for the 224r.. i have no regrets.. just put that sucker in! then if its not enough get some heads/intake.
Old 08-25-2007, 09:02 AM
o2camaross's Avatar
ive got the TR224 on a 112lsa and love it. You wont regret it.
Old 08-25-2007, 11:33 AM
therobman's Avatar
alright im gunna stick with it what kind of heads will flow the best with this cam
Old 08-25-2007, 02:41 PM
therobman's Avatar
anyone?
