Spacers for dual chain not enough to clear oil pump. What now?
Old 08-25-2007, 12:01 AM
SPRAYED 01's Avatar
Default Spacers for dual chain not enough to clear oil pump. What now?
I installed my crane dual adjustable timing chain today. I go to put the new melling oil pump on and i used the two spacers that came with the timing set. Only problem is that the passenger side of the pump does not clear the timing chain still. Can i grind the pump down alittle to try and clear it.
Any other ideas?
Alex
Old 08-25-2007, 01:02 AM
DONAIMIAN's Avatar
You cant use the melling pump with a double roller chain. You have to either run a single chain and the melling pump, or a double chain and stock pump.
Old 08-25-2007, 01:46 AM
navymitch12's Avatar
my melling pump works with a double roller
Old 08-25-2007, 02:07 AM
Sleward's Avatar
How far along the crank snout is your crank gear?
Mine looked like it was on there right but after I got to setting in the cam gear and the oil pump I realized I had to get it further along the crank.
Old 08-25-2007, 02:09 AM
studderin's Avatar
google Adds Suck
Ib Sucks
Old 08-25-2007, 08:07 AM
JPH
JPH's Avatar
false.
i think melling has changed there casting a little, just clearance the pump enough to achieve good room for the chain and you should be good to go. i once had a machinist make me some thicker spacers one time. you can make it work though.
Old 08-25-2007, 08:21 AM
JPH
JPH's Avatar
Originally Posted by studderin
little grinding on some of the letters were the chain passes, and the inside corrner of the pickup bludge.
little were the frontside of the pump, were the outlet bludge in for the passage going into the block. For cover room, and a little grinding on the cover too somtimes.
Use a marker to see were it rubs of.
good answer man.
