Best ET cam with LS6 valve springs?
Old 05-27-2003, 12:01 AM
Terry Burger's Avatar
Default Best ET cam with LS6 valve springs?
I've got a set of 2002 LS6 valve springs I'd like to use, which would be with an otherwise stock 98 LS1. Any suggestions for the ultimate cam with these springs? Any idea on max lift? I'm thinking either 216/220 .525 114ls, or perhaps a 2002 LS6.
Old 05-27-2003, 12:10 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Default Re: Best ET cam with LS6 valve springs?
ASA Cam: 226/236 .525/.525 110
Old 05-27-2003, 12:19 AM
someday's Avatar
comp cams: 224/228-.534/.537-112...
Old 05-27-2003, 12:54 AM
DONAIMIAN's Avatar
took the words right out of my mouth
Old 05-27-2003, 02:16 AM
66ImpalaLT1's Avatar
Terry you should become the champion of all those guys that like the 2002 LS6 cam.
You could be the Fastest "LS6 cam-only" in the country!!
Eric
Old 05-27-2003, 09:25 AM
lol I hate the LS6 cam, but that would be funny!
Old 05-27-2003, 10:06 AM
JS
JS's Avatar
George Benson had the 02 Ls6 springs go flat on him with the ASA.
He was also running the 02 lightweight valves too.
I would run a Ti retainer with them Terry and I wouldnt run a fast ramp.
How about the 218-224 527-534 114.
Its a good cam
Old 05-27-2003, 10:34 AM
Right now I'm going after cheap, I can't afford those big dollar Ti parts. I'll go hunt around MMS and see what I can find in their trash bin.
Old 05-27-2003, 10:50 AM
Jantzer98SS's Avatar
I'll sell you my 224/224 .535 .535 112 when it comes out here real soon.
Old 05-27-2003, 12:07 PM
JS
JS's Avatar
The problem is those springs dont like the heavier valves and rpm.If u can find a set of used Ti retainers that fit the (Comp 918)they will work,Terry.
That'll help a whole bunch as far as float if u decide to run alittle more advanced ramp.
Old 05-27-2003, 01:36 PM
Raven's Avatar
I don't mean to do any thread hijacking, but do any of you guys know what's the highest lift that LS6 springs can (reliably) handle? I have them with my hotcam, but if I decide to go with a bigger cam in the future, or get a set of 1.8 RRs, could I still use them? Or should I upgrade the springs too?
TIA
-Bradster
Old 05-27-2003, 01:43 PM
JS
JS's Avatar
I've HEARD 570 lift with 02 valves and Ti retainers.
I wouldnt run them over 550 lift with the older valves or without Ti retainers.
Old 05-27-2003, 09:06 PM
Raven's Avatar
Thanks, JS
Old 05-27-2003, 09:46 PM
bigSS's Avatar
What lift are the LS6 springs good too? Are stock pushrods fine also for these cams?
Old 05-27-2003, 11:26 PM
badass 2002 z28's Avatar
That 216/220 comp is a great cam and it makes great power with stock heads
02 LS6 springs are rated for
install 1.800" / 90 lbs
max lift 0.600" / 300 lbs
but I wouldn't run anything over 550 lift with them, cuz i know they're not as strong as 918's
Quick Reply: Best ET cam with LS6 valve springs?
