egr on 02ss
Old 08-25-2007, 07:21 PM
Kratos 2250's Avatar
Default egr on 02ss
can i removed the air pump and those rubber hoses that run into my exhaust manifoldswithout messing stuff up?
Old 08-25-2007, 09:50 PM
RE AND CHERYL's Avatar
Just make block off plates for the lines on the manifolds and your set. Aside from about 7 pounds off the nose, it won't give you a thing as the system dosen't sap any power off the engine and only runs till the engine reaches about 150deg.
Re'
Old 08-25-2007, 09:54 PM
ONEBADASSWS6's Avatar
You are talking about the A.I.R. system (Air Injection Reaction), not the EGR. 2002 LS1's don't have an EGR system.
You can pull the lines out of the engine bay without any issues at all, you just need to get block off plates for the manifolds. If you pull the AIR pump itself though and disconnect the harness, it will throw an SES light.
Old 08-27-2007, 05:55 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Just wait until you get headers. No it won't mess anything up, it will just set off the SES light
