LS1 in my wrangler won't turn over
I知 trying to use the stock under hood fuse block on my LS1 jeep project, I知 also using a portion of the chassis harness.
I have 12v on the red pin on the ignition switch (c2), so I jump that to the yellow pin, which is Ignition crank output. I do this to simulate the key turning. However, nothing happens.
I think the problem lies in the relays in the fuse block. So my question is, what is need to happen to get the relays to close? I think the start relay needs some sort of voltage from something. I am not sure if it needs a signal from the park/neutral switch, or from the BCM. Does anyone have any suggestion to get around this problem?
The basic wiring diagram for a Start circuit looks like this:
+12V -------- ignition switch -------- neutral safety switch -------- starter (or relay)
You'll have power on at least one side of the neutral safety switch when you turn the key to Start.
So I got it all to work. This is how the starting circuit works with the ls1 chassis harness.
12v red on ignition switch -- when turn to start it connects to the yellow -- making the yellow wire hot -- yellow goes to start fuse -- on the otherside of fuse is a thin purple wire(which is hot when cranking) -- the purple wire goes to the park/ neutral switch -- when in park or neutral the circuit is connected an 12v is now present on the dark green wire -- that wire travels back to the under hood fuse block to the start relay -- then coming out of the relay is a yellow/black wire -- that goes to the BCM(I just jumped it to ground at the connector) So since the entire circuit is complete on relay's secondary side, the switch is closed sending voltage to the starter.
Think you guys for the help. Now I just need to get a park/neutral switch
Now onto the fuel relay
