Is it possible to find a LS6 intake at a junkyard?
Old 08-26-2007, 06:46 PM
Yahelou's Avatar
Default Is it possible to find a LS6 intake at a junkyard?
I know the ls6 intake came standard on 01-02 ls1s. and I think they also came standard on corvettes (not really sure). i was thinking about this a couple of days ago, wouldnt be possible to find one of those cars in a junkyard and pull it out and use it? If it is possible, what other items would be needed to be pulled out to use?
Old 08-26-2007, 07:01 PM
'99bluez's Avatar
LS6 intakes are found on '01-02 f-bodies, '01-04 'vettes, and '04 GTO.
Yes its possible to find one in a junk yard, but not likely. Atleast around me its a rarety to see a late model f-body or 'vette in a junk yard. Usually when these cars are totalled someone usually parts it out or sells the car as a whole - they rarely end up in jumk yards because they are very desirable.
Old 08-27-2007, 01:18 AM
CW00BlackTA's Avatar
You'll also find that the junkyards won't let you take parts off an engine, they'll want to sell the engine as a unit.
Old 08-27-2007, 01:52 AM
Ferocity02's Avatar
I've tried this also but rarely will you find one. As mentioned, they want to sell the motor as a whole piece. Also, these cars make up a very small proportion of the dismantled cars out there. And finally, I guarantee you there are many others in your area with the same idea who are trying the same thing.
Old 08-27-2007, 04:09 AM
njc.corp's Avatar
i have one if u need off a monaro 02-03 - u guys call it a gto-
ls6
can supply part no if needed-
i am in aus but can freight-to u.s.a
Old 08-27-2007, 10:03 AM
Yahelou's Avatar
well it doesnt hurt to try. im gonna call around and maybe ill find something. but i was thinkin it would be hard to find any one of those cars in a junkyard.
Old 08-27-2007, 05:26 PM
Moderator
davered00ss's Avatar
If a junkyard has an Ls1 engine, they are going to want to sell it complete. I doubt they would sell just the intake. they are cheap enough on the boards or ebay. Normally $300 shipped. You can find them cheaper if you look.
Old 08-27-2007, 05:53 PM
Yahelou's Avatar
oh yea, i forgot to ask, how can i tell a difference between a ls1 intake and a ls6 intake??
Old 08-27-2007, 06:20 PM
'99bluez's Avatar
the bottom side of the LS1 is wavy and the bottom side of the LS6 is flat there are plenty of pics floating around - see if search is working
Old 08-27-2007, 10:42 PM
Tathy's Avatar
good luck trying to find one at a junkyard
Old 08-27-2007, 10:54 PM
BriancWS6's Avatar
I agree with everyone else. Even if you were to get lucky enough to find one in a salvage yard, they wouldnt sell it a piece at a time, it would be all, or nothing.
There are several ways to tell if it's an LS6 intake or not, one easy way, would be that the LS6 doesnt have provisions for EGR.
Old 08-28-2007, 06:35 PM
Yahelou's Avatar
well i called around and found one for $250. what do u guys think?
Old 08-28-2007, 06:38 PM
Trunion King
bene's Avatar
Take it!
Old 08-28-2007, 07:39 PM
tripps's Avatar
Dear lord yes take it now before someone else does! 250 is a badass price for one, just make sure it isn't cracked or anything. You never know..
Old 08-28-2007, 10:59 PM
BriancWS6's Avatar
That's a nice price if it's indeed an LS6, and doesn't have any damage.
Old 08-28-2007, 11:17 PM
Yahelou's Avatar
sounds good. im gonna pick it up on friday and im gonna inspect it throughly. should i get anything else with the intake, like coolant lines, while im there?
Old 08-29-2007, 02:17 AM
waldershrek's Avatar
I'm sure it's possible but probably not likely
Old 08-29-2007, 06:50 AM
Internet Mechanic
BlackScreaminMachine's Avatar
CHeck the FS section
Quick Reply: Is it possible to find a LS6 intake at a junkyard?
