i wonder what I broke....
Ok, to make a long story short, I was being and idiot and I spun out going 100 mph. I went around in two circles, the second one was off the side of the road. The outside of my DS front wheel hit the ditch hard enough that little rocks broke the bead in the tire. I got the tire fixed but I think I broke something else. I have a constant break like (like when your pads need replaced) squeal from the wheel at all times that my wheels arent pointed even slightly to the right. Also when I break I get a "wa-wah-wah" noice from the wheel area also.... If anyone could help me out I would be much thankful...
Thank You,
-Ronnie
Thank You,
-Ronnie
will do, Im headed out to try and get to the bottom of this now. If anyone else has suggestions, Ill be coming back in to check the thead every so often... thanks again fellas.
I couldnt find anything at all. Everything was tight and intact. I really hope it's not a bent wheel.
Yes I know Im lucky to be alive, I was actually passing a tanker semi when I spun. I was going in circles while I passed him. Shot back out into the road right beside it. Close call for sure.
Ok Ive had my new rotor on for two days(the noises had stopped). Now the squeeking and the grinding noise at low speeds is back. Its no doubt coming from the breaks/rotor. What else could be broke?
