Water in floor from A/C
Well today i noticed there is water in the passenger side floor from the a/c. what does this mean? I havent had time to look at it yet but will try to tomorow.
My girlfriend has the same problem. I even by passed the heater core just to make sure it's not coming from that but I still have water from the air conditioning. It's just one more thing I got to fix.
If its clear water on the floor its condensation from the a/c. Like Black Bird says its the evaporator drain. Look outside the pass. firewall for a short rubber tube about 1/2 way down. Blow a little shop air, use a wire or a pipe cleaner in it. You'll dislodge a leaf or some crud and the water will then drain. Its why all cars with a/c leak water behind the r/f tire on a muggy day.
Johnny
Johnny
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/730709-c-leaking-inside-floorboard.html
go to that thread i started, had the same problem like he said just take a air gun to it and clear out the drain, in one post there is a pic showing where it is.
Happened to me recently. Go under your car, locate a black resevior with a small hole in it to the right of your passenger side cat (thats where it was on my car at least). My drain hole was clogged with dirt so I stuck a wire up into it and cleared it out. dont stick too far though, might damage something. Hope this helps
