LT1 Making noise and volts are low????
Old 09-04-2007, 07:17 PM
losaltos6's Avatar
Default LT1 Making noise and volts are low????
So me and my brother-in-law have a auction license and we are mainly buying z28/trans ams and selling them. Well we found a real nice z28 with 124k on it and when we started it up the belt made a ton of noise and the volts were low, about have way into the red. We turned off the car and inspected the belt and it was lose and it looked like it need a new one. I really don't know whats wrong with it but my main guess is that it need a new alternator becasue when the car runs it make a weird sqweeking/grinding sound and it seems to be coming form the Alt. Also i kinda smell a bit of gas too
I don't know but what do you guys think it might be.
Old 09-04-2007, 08:40 PM
dhdenney's Avatar
Sounds like maybe the bad belt ruined the bearing in the pulley. And if the belt was slipping or something , maybe not turning the alternator fast enough to charge. Gas smell could be anything. Leaky exhaust? Just loading from not being driven in a while? Bad coolant temp sensor (fueling incorrectly cuz it doesn't know how hot it is).
Old 09-04-2007, 11:00 PM
losaltos6's Avatar
Jesus, too many things.lol well i guess well see if we get it or not. guy is asking 4k for it witch i think is to much because of that problem and the whole front bumper cover is primerd.
Old 09-05-2007, 12:09 AM
Revelation Z28's Avatar
the alternators in our cars and alot of LS1s go out numerous times. some only last 10-40k miles.
Old 09-05-2007, 09:23 AM
dhdenney's Avatar
Mine's got 110k on it. I would replace the alternator and the belt and that would take care of most of it. Yeah $4k is too high all things considered. You gotta replace the alternator and belt (~$150) paint the front bumper cover (~$500 on up) and whatever else is wrong with it. Then you turn around and sell it for not much more than $4K anyway.
Old 09-06-2007, 09:37 PM
B4C_LT1's Avatar
if it has a UD pulley that could be the reason for low voltage....at idle anyways
Old 09-07-2007, 06:25 AM
Formula350's Avatar
My guess is just a bad alternator. When they go bad (bearings, voltage regulator) they get harder to spin and start to make noises. That, and with more friction the belt will start to slip and make it's own noise. I'm sure a new alt would fix that car right up.
Quick Reply: LT1 Making noise and volts are low????
