Video thread! LT cars with Forced Induction?
Old 09-05-2007, 12:02 AM
phantomLT1's Avatar
Default Video thread! LT cars with Forced Induction?
I would like to see videos of forced induction LT1-LT4 cars. Any forced induction. (Turbos frontmounts,rearmounts,procharged,supercharged). Thanks
Old 09-05-2007, 08:03 PM
nick97ta's Avatar
here you go. they are of when I first got the car running and had a little over oiling problem.
it's a little long may want to fast forward to the last 30sec.
http://s8.photobucket.com/albums/a37...t=TurboTA3.flv
this is very long... go to the last 30sec. and you can still see the smoke in the dark.
http://s8.photobucket.com/albums/a37...t=TurboTA4.flv
in short the vids suck.
Old 09-05-2007, 10:14 PM
phantomLT1's Avatar
Default Sounds mean as hell
Is that an STS or front mount.. More about your setup and power you put down? Thanks man .
Old 09-06-2007, 04:35 PM
nick97ta's Avatar
It is a front mount, that me and a buddy built.
I have not checked to see how much power it produced, because I pushed the head gaskets out on 12psi and over heated the motor. I have installed new cometics and got the car running but the heat got the rings and it's down on power. I've got a boost friendly motor in the works, when its in I will find out how much power it puts out.
the turbo is a gt42 76mm.
Old 09-06-2007, 04:56 PM
Websy21's Avatar
sounds and looks great
Old 09-07-2007, 09:49 AM
RealQuick's Avatar
Nick, sucks to hear about the head gasket. I have been waiting to see some of your results.
Jon
Old 09-08-2007, 10:31 PM
nick97ta's Avatar
Jon
I was going to do some racing to day then it started raining. so that was out. the car runs just not up to par. I do have another block that is ready for the machine shop, a set of 210 AFR's and will order my rotating Assembly by the end of the next week, looking at a comp star rod and crank with JE pistons at 9:1cr.
Old 09-08-2007, 11:04 PM
Moderator
FANTAZ28's Avatar
http://www.fquick.com/videos/Turbo_C..._BBC_Nova/2592
there you go , not sure if you meant lt1 body cars or lt1 motors... its a 95 with an ls1
Old 09-09-2007, 11:08 AM
Reject's Avatar
check out some vid's from BigRick, that thing is nasty!!
Quick Reply: Video thread! LT cars with Forced Induction?
