Video thread! LT cars with Forced Induction?
I would like to see videos of forced induction LT1-LT4 cars. Any forced induction. (Turbos frontmounts,rearmounts,procharged,supercharged). Thanks
here you go. they are of when I first got the car running and had a little over oiling problem.
it's a little long may want to fast forward to the last 30sec.
http://s8.photobucket.com/albums/a37...t=TurboTA3.flv
this is very long... go to the last 30sec. and you can still see the smoke in the dark.
http://s8.photobucket.com/albums/a37...t=TurboTA4.flv
in short the vids suck.
Sounds mean as hell
It is a front mount, that me and a buddy built.
I have not checked to see how much power it produced, because I pushed the head gaskets out on 12psi and over heated the motor. I have installed new cometics and got the car running but the heat got the rings and it's down on power. I've got a boost friendly motor in the works, when its in I will find out how much power it puts out.
the turbo is a gt42 76mm.
Originally Posted by RealQuick
Nick, sucks to hear about the head gasket. I have been waiting to see some of your results.
Jon
Jon
I was going to do some racing to day then it started raining. so that was out. the car runs just not up to par. I do have another block that is ready for the machine shop, a set of 210 AFR's and will order my rotating Assembly by the end of the next week, looking at a comp star rod and crank with JE pistons at 9:1cr.
Moderator
http://www.fquick.com/videos/Turbo_C..._BBC_Nova/2592
there you go , not sure if you meant lt1 body cars or lt1 motors... its a 95 with an ls1
