blocking AIR system (ticking noise)???
Old 05-29-2003, 03:30 PM
VTtransam's Avatar
Default blocking AIR system (ticking noise)???
I just started getting that annoying check valve ticking noise from the AIR system. I'm not sure if I want to block it off, or drill a hole in block-off plate and put it between the header and the AIR system connection. I read somewhere that this works. What size should I drill the hole? I'm hesitant to block the system off because I'm running cats and I understand it helps them heat up faster, putting the pcm into closed loop mode sooner. Anyone try this, or have any suggestions for me?
Thanks
Matt
Old 05-29-2003, 05:53 PM
WILWAXU's Avatar
Default Re: blocking AIR system (ticking noise)???
All you need to know
http://riptide63.homestead.com/restrictor.html
Old 05-29-2003, 08:59 PM
42NightZ28's Avatar
just toss the whole AIR system thats what i did!
Old 05-29-2003, 09:05 PM
NiceTry's Avatar
ditto
Old 05-29-2003, 09:44 PM
ngozer's Avatar
that's what i did also. plus it makes the engine bay look alot better.
Old 05-29-2003, 10:11 PM
98 LPE SS's Avatar
If you decided to keep the AIR tubes, Pace sells a restrictor kit so you don't have to make them your self.
Old 05-30-2003, 08:18 AM
Shane's Avatar
If you decide to keep the AIR tubes, you'll most likely have to replace the check valves also to stop the ticking...
I just removed the AIR tubes...for off-road use only, of course...
Shane
Old 05-30-2003, 09:15 AM
NCTRNLS1's Avatar
What do you have to do to get rid of the AIR System? On a 98Z
Old 05-30-2003, 09:18 AM
Viper's Avatar
https://ls1tech.com/threads/showflat...rue#Post542347
Old 05-30-2003, 01:32 PM
VTtransam's Avatar
Thanks for the responses! I was going to toss the AIR system all together, but then while I was doing a search, I read that my cats would burn up quicker without the AIR system. Is there any truth to this? I'm not really sure how the PCM works but one post said without the AIR system the PCM takes longer to get into closed loop mode. Can anyone shed some light onto this subject? Thanks
Matt
Old 05-31-2003, 07:19 AM
BIG PD's Avatar
then just get rid of your cats too! jking...kinda
yah dude the AIR system puts oxygen into your exhaust. **** gets hotter if there's oxygen in it i guess and it does heat up the catalytic converters much faster then without the system. it won't harm them though...and so what if they do.
Old 05-31-2003, 07:41 AM
Assassin's Avatar
I hate the cats, I'm cutting them out and welding pipe in place as soon as........... I get around to it...
Old 05-31-2003, 04:41 PM
Bear's Avatar
Cats are only good if u are going to pass the sniffer to begin with. If not, then get a big cam, ditch the cats, and make some real noise.
Old 05-31-2003, 05:54 PM
VTtransam's Avatar
I would have tossed the cats a while ago, but I have to pass emissions (the sniffer). It goes for inspection this Monday, so we'll see how that goes. I took the whole AIR system out last night and the car seems to stumble a bit more than it did before when cold. I'm going to ditch the cats when I save up enough money for Hooker LT's and custom true duals over the axle. Emissions testing might be the biggest statewide scam ever!
Matt
Old 05-31-2003, 07:10 PM
Mike K.'s Avatar
I was thinking of removing my air system as well when I ditch my SLP headers, it does seem weird though that injecting air helps to heat up the cats quicker? I guess thats why I'm not an engineer.
Old 05-31-2003, 10:29 PM
Doc
Doc's Avatar
Hey Mike, I'm just a "dumb *** mechanic," who loves to screw with the engineers I work with every day...remember the fire triangle from school? Fire/Heat, Fuel-unburnt escaping in xhaust, and ta da O2. Now I am sure my engineers could give it to you in a very impressive, thorough powerpoint presentation-only it would take em' 6 months to gen it up.
Old 06-01-2003, 06:42 PM
VTtransam's Avatar
well, It wasn't the AIR system. Noise is still there after blocking it off. I'm going to head over to Internal Engine.
Matt
