Drag Racing Tech
Bracket Racing..Powerglide ??s
Old 09-07-2007, 10:20 AM
redneck01's Avatar
Default Bracket Racing..Powerglide ??s
I'm planning my 383" LT1 bracket race build for next season and I'm planning on a pretty serious N/A setup to hopefully race every other weekend. For consistency and E.T.'s I wana use a powerglide transmission, but I have only really seen f body guys use t350 and t400's.
If I run the 'glide, should i go with the 1.76 or 1.82 gear, and do I need the short or standard length? thanks guys
Old 09-07-2007, 10:40 AM
WE TODD DID's Avatar
I would do a 1.76. You don't want a bracket car being violent on a launch. Get the standard length. The shorts are usually for dragsters. Also be sure to get the bracket brake in the trans as well.
Old 09-07-2007, 03:59 PM
8 second club
G&HRacing's Avatar
Stock planetaries, I'd definitely go with the 1.76's, 1.82's are weak. If you're buying after market I'd go with a 1.80 planetary. I'd go with a pro brake, but that's just my opinion. I don't think you'll be in danger of hitting the tires too hard with a naturally aspirated 383.
Old 09-07-2007, 04:30 PM
redneck01's Avatar
thanks guys for pointing me in the right direction. im assuming most any bracket classes that allow th350 transmissions will allow 'glides. thanks again
Old 09-10-2007, 11:02 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Most bracket classes will allow any transmission, but as mentioned most go 2 or 3 speed for consistency. I run a TH400 in my Nova for the fact I still drive the car on the street and the first gear (2.4 something) will launch harder than the 'glide's 1.76. I will say that most 10 second and faster cars tend to lean towards a 'glide b/c of the previously mentioned launch characteristics. Just remember some bracket classes won't allow a transbrake, but you can always remove the wires to the solenoid. If using a TH400 or 'glide, I'd get a brake added.
Derek
Old 09-10-2007, 03:28 PM
6 & 8 Second Club
mrdragster1970's Avatar
1.80 straight cut & the pro brake. With a small block you will be set for life. Should be stronger than you will ever need.
Old 09-10-2007, 09:45 PM
promod1955's Avatar
1.80's with a pro brake is a proven combo.
I'de also call ATI as there in your backyard. A customers car of mine runs 4.20's in the 1/8th and is fully capable of 4.10's, and he runs an ATI powerglide. I run one in my car as well with 0 problems.
Old 09-11-2007, 07:43 PM
redneck01's Avatar
thanks for the pointers everyone..lotta help. thanks
Quick Reply: Bracket Racing..Powerglide ??s
