E Boost 2, help fast
Old 09-07-2007, 11:43 AM
Firechikn's Avatar
Default E Boost 2, help fast
Eboost 2. I can't switch the set points. The boost groups are set up in the menu, just can't switch on the controller. It says use the up and down, but they don't work. I did it by accedent once but I can't duplicate.
Old 09-08-2007, 12:47 AM
cablebandit's Avatar
hit the mode button on the left once so it says sp1....then use up/down buttons to switch to sp2...etc. it will always defult to sp1 on startup
Old 09-11-2007, 07:24 AM
Firechikn's Avatar
I must be a tard. I tried again last night and still couldn't switch to sp2. When I hit the mode button it shows sp1 then boost setting. Hitting the up and down still doesn't do anything. I'm going to go through the setup menu again and see if I'm missing something. Believe it or not, I can cruise through setup and boost menus pretty good now, only took 100 tries.
Thanks C.B. for the reply.
Old 09-11-2007, 08:14 AM
you did set it up to have 2 seperate setpoints correct? in one menu, it asks how many setpoints you want...default is sp1
Old 09-11-2007, 08:18 AM
LS1Tech Sponsor
Superman09's Avatar
Yea, i was toying with mine a bit last night and after hittng mode it goes to SP1, then u cant scroll. I did hit menu and down at the same time and it opened another menu. I need to read the manual to better understand this. Any of you guys have the RPM wire set up? If so exactly where do you connect it at?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 09-11-2007, 08:28 AM
Firechikn's Avatar
Yeah, in the setup menu I set the sp to 3 ( 3 boost groups ). In the boost menu I setup all 3 but can't access. I switched it once but I can't do it again. I'm wondering if maybe it didn't save or something. Hitting mode and up doesn't change it so I've got something wrong. I'm not using any rpm bases functions at this point, so its not connected. Just using the boost settings to turn on the meth pump. Thanks for the replys, any more thoughts.
Old 09-11-2007, 12:22 PM
RW99's Avatar
God I wish they'd enable some sort of software-based programming for these things.
Old 09-11-2007, 01:10 PM
maybe you changed the WAY you switch them...there is a setting for switch based...rpm based etc
Old 09-11-2007, 01:54 PM
Firechikn's Avatar
That's what I'm thinking. I think you can configure the buttons different too, if I remember correctly. I've got the menu's down now, so I think I'll reset and start over. This is a nice controller once you figure how to program it. It has way more function than I'll use, but the recall and over boost is nice.
Old 09-11-2007, 04:30 PM
TT-TECH Veteran
Inspector12's Avatar
You should be able to puch it again and it should start flashing while flashing use the arrows to scroll to sp1 or sp2 etc... and then push the mode button again to lock it in. That is how mine has worked took me a while to figue it out LOL!
Old 09-12-2007, 06:51 AM
Firechikn's Avatar
Ah, success. Went through the whole setup menu and reset. Looks like I was in rpm mapping mode. Now I can push up and down and it switches like its supposed to. Thanks.
Old 09-12-2007, 08:31 AM
TT-TECH Veteran
Good to hear!
Old 09-12-2007, 11:01 AM
good to hear. my sp1 is normally 5psi...sp2 is 9.5psi
I forgot i swapped them at the track this weekend and left a store yesterday WOT (on 9.5psi thinking it was 5 psi). I spun the MT DRs for quite awhile...saw all the smoke and thought "oh ****" until i SMELLED the smoke I really like my eboost2 and have had ZERO trouble out of it
Old 09-13-2007, 07:24 AM
Firechikn's Avatar
A friend of mine has the EB1 and has had good luck with it. I like the recall, and the ease of switching set points. All the mapping would be cool too if you wanted to take the time to set it up. I'm only using the switched output to turn on my meth for now.
Quick Reply: E Boost 2, help fast
