question about the air pump system
Old 09-07-2007, 05:16 PM
98mysticZ's Avatar
Default question about the air pump system
hey what sensors detect that the air pump is "working" o2's or what? i dont have cats and was going to just block off the plates But what about just putting in 2 like small k&n filters on the pump so it still turns on and stuff?
Old 09-07-2007, 06:40 PM
3.4camaro's Avatar
Just take out the pump. I'm sure it's diagnosed by the pcm, which would detect if there is a short to ground, or an open in the circuit.
O2s dont come into play until closed loop.
Old 09-16-2007, 04:34 PM
RE AND CHERYL's Avatar
Air pump is run off a relay so even if you remove the pump the PCM will never know.
The pump is also only running for about 5 minutes after startup, most to all of that time the engine is in open loop operation.
Re'
Old 09-16-2007, 05:54 PM
8a8mfh's Avatar
On my 2002 there are 5 diagnostic codes to disable when you remove the AIR system.
Disconnect it and the vcm will detect it.
Old 09-16-2007, 06:09 PM
oange ss's Avatar
no it wont....
Old 09-16-2007, 06:58 PM
3.4camaro's Avatar
Yes, it will. If the AIR pump is working properly, the rear set of o2s will read no fuel in the exhaust, because the AIR pump pumps air into the exhaust to be burned with excess fuel that is squirted during open loop.
If the pump doesn't work, the rear o2s will fluctuate like the front ones, setting off the SES.
trust me, I've had the SES come on due to this.
Old 09-16-2007, 07:02 PM
oange ss's Avatar
there is no feedback loop in the AIR system, other than relay staus...
Old 09-16-2007, 08:38 PM
8a8mfh's Avatar
I have no AIR system and no SES light because I deleted the codes. Do/believe what you want.
Old 09-16-2007, 08:44 PM
8a8mfh's Avatar
It blows air OUT of the two hoses that connect to the exhaust so they don't need filters.
IMO if you're going to leave all that **** in there, just leave it connected.
My car was programmed to run the AIR pump for 90 seconds at cold start, so unless you're worried about a peformance loss during warm up, leave it there and connected.
