317 heads any good or go w/ aftermarket?
Old 09-10-2007, 05:00 PM
TINKRD's Avatar
Default 317 heads any good or go w/ aftermarket?
should i invest the money and CNC some 317 heads i have or should i hold that money and invest in some aftermarket cast that provide a thicker deck? Dart, AFR, ETC?
408, GT47-88 that will see 15+lbs
Old 09-10-2007, 05:08 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
How fast you want to go? I'd say if you shoot for faster than mid 9's you should go for thicker deck aftermarket head castings.
Old 09-10-2007, 06:07 PM
stevieturbo's Avatar
The Darts are probably the best value out there....so probably makes the most sense.
Old 09-10-2007, 07:17 PM
slowredz's Avatar
JP, for what you want to do I would say go aftermarket if you have the money. I just picked up my DARTS last week from RAY MAC.
Old 09-11-2007, 11:35 AM
red90cobra's Avatar
i'd say go for aftermarket too. nice heads josh.
Old 09-11-2007, 01:29 PM
TINKRD's Avatar
thanks for the info guys. i'll be doing this if i can get my money back on the 317s...
Old 09-11-2007, 11:04 PM
SSilverSSurfer's Avatar
sorry to invade the thread but would untouched 317's be fine on a 347/76mm build? or should i have them worked? would the extra work be noticed? thanks and sorry for the intrusion
Old 09-12-2007, 09:07 AM
LS1Tech Co-Founder
You can run unported heads with stock valves if the budget is not there, but if you look around you can find some good deals on used heads, or even ported OEM castings from places like TSP, TEA, and Patriot.
Old 09-12-2007, 09:22 AM
Speed's Avatar
I thought I read somewhere that the 317s had a thicker deck than the 243/241 and older castings. If that's the case, I wonder how much thicker the casting on an AFR or the like is than a 317?
Quick Reply: 317 heads any good or go w/ aftermarket?
