what oil filter are you using
I have an oil cooler on my car with the PF 1218 and it hangs low but other things will hit that before the filter does. Also one benefit is that it makes it much easier to get the oil filter wrench on...
I use K&N's offering on my T/A .. after seeing this
http://minimopar.knizefamily.net/oilfilterstudy.htmls i wouldnt run anything else
Yay for being a nerd.
He added an S on the end of the link.
EDIT: Interesting read, but gave no incite as to why you run the K&N filter Unless it makes your oil turn into Royal Purple
I met a k&N rep and was told that their filters were the same filter a Mobile One filter with the exception of the nut on the end for safty wire and a thicker can material. The 454 crosses over to a 602 Mobil one one filter but double check. You will notice that your oil stays clear a lot longer with this filter.
