how to get pilot bearing off?
Old 09-12-2007, 06:45 PM
noxiouSS's Avatar
Default how to get pilot bearing off?
whats the best way to get it off?
Old 09-12-2007, 06:52 PM
brad8266's Avatar
Use a pilot bearing puller.
Do not attempt to use the old school trick of stuffing wet paper towels in it to force it out, all that will do is push the crank freeze plug out the back and into the oil pan. You dont want that.
Old 09-12-2007, 07:49 PM
kingcuda70's Avatar
Find the "blind hole puller" on the loan-a-tool part of Autozones website, print and and take it with you or call - if your 'zones like mine those folks will need all the help they can get to find it. It's free for 180 days..
Old 09-12-2007, 10:36 PM
Schitzo's Avatar
same thing happened to me
do a search here and get the part number for it. It works great.
Old 09-12-2007, 11:01 PM
Vertigo's Avatar
Good LUCK! Use the blind hole puller but be Sure you get it nice TIGHT, and most importantly LEVEL your first shot. You don't want to round the edges off the back side b/c the next time the puller will just slip right off. So WD-40 the **** out of it the night before. If worse comes to worse as it did with me...you can always take a very small hacksaw blade and cut out 12'oclock to 3'oclock then pull it! It's a bitch though.
Oh and one more thing. Put your new pilot bearing in the freezer the night before.
Old 09-13-2007, 02:46 AM
nighthawk15's Avatar
Bearing puller for sure. Like said above make sure it is tight, but don't over tighten it! Ask me how I know if you must, LOL. I know I'm an LT1 guy but I would think something as simple as the pilot bearing would be pretty similar (with the exception of that you cannot use the wet toilet paper or grease methods because of the hollow crank). That thing was the absolute hugest bitch in my entire clutch swap. Couldn't get a single shade tree mechanic trick to work and ended up running to autozone the next day for a bearing puller.
Old 09-13-2007, 07:31 AM
KtownGoat's Avatar
i used a hook and a slide hammer, it was a bitch though...
Old 09-13-2007, 08:04 AM
moserman's Avatar
i pumped mine full of grease and then used a slide hammer and it came out.
Old 09-13-2007, 09:24 PM
noxiouSS's Avatar
alright. Thanks guys.
Old 09-14-2007, 08:24 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Thats what we used, worked fine, the bearing was destroyed but who cares.
Old 09-14-2007, 05:47 PM
TheLS1Kid's Avatar
I'd just get the correct puller to be safe.
Old 09-14-2007, 07:44 PM
bayer-z28's Avatar
Hmm.. I suppose that goes the same for packing it with grease..... THanx for the heads up. I won't try that.. I didn't replace my PB when I did my clutch and trans.. I just gouped it w/ some white lith and anti-seeze and rolled it around in there..
Quick Reply: how to get pilot bearing off?
