HELP??? #8 primary glowing
Alright so far i have done a compression test and it is 155 PSI, I have have listened to the valvetrain and it sounds ok, I changed the plugs why Only this one cylinder?
Thanks
Brian
Thanks
Brian
Moderator
#8 is going to see the least cooling airflow, shrouded as it is by
the firewall and the A/C clutter. Plus it's the darkest part of the
engine compartment so will show better. If you look at them all
at night, do they appear more balanced?
Have you used a laser thermo heat gun and looked at the primarys to see what the temps are idling? Ive got 3 that are near 700 degrees idling turns out I have a voltage issue to the injector connectors which I think come strait from the pcm. Anyway off subject but I was just trying to find out how hot they were
