What the fuck went wrong....
What the **** went wrong....
Ok just did the disabling the automatic headlights and everything worked great andthe lights are now manual... but now the lights for the gauges dont work!! The brake light and asr off and crap still light up...
The interior lights still work but as of right now... the gauge cluster is off, the radio is off... Me and my buddy are stumped....
Any help woud be great.
Thanks,
Taylor
Thanks,
Taylor
well its late and all i can suggest is check your fuses... sounds kinda crappy but the way everything sounds i would start with that and if that doesnt work. i would go about getting a wiring diagram and seeing what all those systems/components have in common....
You probably have a hot wire that is grounding causing the fuse to blow. Check all you connection and make sure you didnt unintentioally fray any wires in the process of your install. <-That sounds like what may have happened.
