just got done porting my stock TB but somethings wrong. need nelp!
so, i just got done porting my TB and it will not close all the way. it's not because i went to far with the porting, it just won't close for some reason! anyone with any suggestions please chime in. thanks
Hey, i just got done with mine today also and had problems getting it closed. just fanagle with it and it sould work. i ended up swapping it backwards (the front face facing backwards with the little air hole still at the bottom) and it worked fine for me
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Take that spring and wind it up one more time. If you get it too tight you will know. It will have a mind of it's own. You will feel the pedal have a tighter feel if it is wound a little tighter. If it is effortless to push down then it probably does need another revolution.
