take a look spark plug
take a look spark plug-- HELP Now
I took out two of them to see what they looked like i i am finlaay going to change them tm i just went and got some TR55's i think these are the stock plugs and the car now has 113k on it i bought it 8mo ago with 100k on it.. also what is the sensor on top of the manifold pics were from my phone not the best
That is the MAP sensor, and the plugs dont look abnormal, just very old
Gap your tr55's at ~.035, make sure nothing is crossed, and you will be a happy camper :thumbsup:
I bet my plugs are original, or damn close. So I'm excited to do them. Since my fuel filter made a big diff. I remember doing them in my old 94 Park Ave 3.8 and the gap tool (just a disc) didn't have a size to measure how gapped they were. It was horrible LOL The cat, removed it, and I got 60+ miles per tank since it was so clogged.
And yes, thats your MAP sensor.
i just broke #8 off and its seized in the block iam going from under the car with s\tarter off i dont have a braker bar my lazy as\s\ brother in law is\ s\till s\leeping
wow that was fun pass side is done it actually would have been that bad if #8 was\ so fucked two more to go on driver side if it wasnt for #8 this could have been done in 2 1/2 hr pshh and gm wanted 800 to change them me gm
Originally Posted by letsrun97z
well #6 wire was ripped=**** replacing wires now
Be prepared for more - I went from plugs - to wires - then broke the opti nipple off when doing the coil wire.
Yeah plug access improves greatly with headers, LT's anyway. The OP's plugs look fine. You want to gap the plug at .050" for stock. I would think anything wider than that would have trouble sustaining the fire but some of you all disagree. The reason you go closer for nitrous/high compression/forced induction is so you don't blow the spark out.
