90mm intake port matchted to afr205s, will intake work on stock heads?
Old 09-17-2007, 07:08 PM
themack56's Avatar
Exclamation 90mm intake port matchted to afr205s, will intake work on stock heads?
well im looking at a fast intake 90mm that has been port matched to afr 205s, will the porting benefit me, or will there be a prob on my stock heads?
Old 09-17-2007, 08:25 PM
themack56's Avatar
anyone?
Old 09-17-2007, 09:09 PM
chefman's_TA's Avatar
you'll be fine.
I have 90/90 setup, ported, and I'm running stock heads.
I've been itchin to get me some afrs.. 450+ here we come
good luck
Old 09-18-2007, 08:23 PM
themack56's Avatar
does anyone elso know?
Old 09-19-2007, 08:38 AM
themack56's Avatar
anyone else?
Old 09-19-2007, 12:21 PM
LS1TECH Sponsor
badpewter-z's Avatar
it should work but will be turbulence . best thing to do is pull the intake apart and put the bottom half on and see where the ports line up or if they are off to much . you may be able to open up your heads to the fast ports but not 100% on that
Old 09-19-2007, 07:43 PM
themack56's Avatar
will the turbulence affect the gains i get, am i gonna see minimal, to the ls1 intake?
Old 09-20-2007, 06:26 PM
themack56's Avatar
porting experts help
Old 09-20-2007, 07:09 PM
SSTAHOE6.0LQ9's Avatar
Default intake port velocity matters
Personally from my experience working at Edelbrock for several years I was trained and always told that general rule of thumb is you can have a smaller intake port runner exit going into a slightly larger cylinder head port entry to promote airflow velocity, but you cannot ever have a larger intake runner exit going to a same size or smaller port entry on the heads.
That will cause turbulence and hurt port flow velocity.
By the way.............
Stock 200cc volume cathedral intake port size on LS1 sand cast heads are: 1.036"
And LS6 intake port size is 1.101"
Measure the intake port exit and compare to your heads entry.
I am not sure about intake port specs on the LS6 SPM(Semi-Permanent Mold) heads.
But, they should be very close. These are the ones with a triangle symbol casted under the exhaust port between the head-bolt bosses on the sides of the cylinder heads
Old 09-25-2007, 07:08 PM
themack56's Avatar
well i measured the intake ports they are 3cm which is 1.2 inches
