Poly engine mount install feedback??
Old 09-18-2007, 04:33 AM
PlatnumStatuz's Avatar
Question Poly engine mount install feedback??
I have my engine out right now and I'm thinking about installing some polyuerathane motor mounts when I put it back in. I'd just like to get some feedback from people that are running these as to how they compare to the stockers in terms of vibration, shaking? Car is cammed and I want to minimize vibration and noise as much as possible so I'm leaning towards running the stock mounts but I know the install is a PITA so I don't want to miss an opportunity for a relatively easy install when I put the motor back in.
So folks that switched to poly, any regrets? Anyone switch from poly to stock?
Old 09-18-2007, 06:04 AM
Thorny's Avatar
I switched to poly to stop my exhuast from banging. I haven't had any negative side effects from it and l am completely happy with the swap. I now have NO exhaust problems due to engine movement. If you're running a cam I would recommend doing it since you will be placing alot more strain on the mounts.
Old 09-18-2007, 08:00 AM
DirtyJohn's Avatar
Do the motor mount, leave the trans mount stock.
I can't feel the motor shake, but I can DEF feel the trans vibrate.
And the trans mount is cake, literally like 5 bolts to replace, the motor mounts are hard.
Do them while you have the easy shot.
Old 09-18-2007, 08:07 AM
myfast70's Avatar
I just did a cam swap thru the engine drop method, definitelly do the engine mount now! The trans mount is what causes mos of your vibration usually. I would put a new stock trans mount on for now if your worried about vibration and see how it holds up.
Old 09-18-2007, 08:40 AM
Fb0dy0nly's Avatar
everyday I walk past the box of poly motor mounts just sitting there on the table and they give me the stare-down. I really am not going to enjoy putting these on but sometimes I want to stop my car and rip off my ORY when I am driving. Sorry for the hijack....they help a lot, put um in.
Old 09-18-2007, 04:12 PM
Da Swami's Avatar
They are definitely nice. Plus, when you "hand throttle" the engine, i.e. revving it from the engine bay by manually turning the throttle cam, people go "holy **** the engine pulls the whole damn car with it!"
Also, I have a poly trans mount as well and I noticed no extra vibration.......
Old 09-18-2007, 09:20 PM
hammerhead's Avatar
If you've already got the engine out, you might as well upgrade. I bought some Prothane motor mounts which I planned on installing along with my AR headers, but everyone I talked to said there was no need to swap the mounts for the AR's. They were right. I still have the OEM motor mounts in my car and I have zero issues with vibration or Y pipe banging. I'll sell you my Prothane mounts cheap if you want them. PM me. I don't plan on pulling my motor and upgrading the mounts anytime soon, but I do think the PU mounts would be an improvement.
Old 09-18-2007, 09:27 PM
ONEBADASSWS6's Avatar
I have polyurethane mounts for both the engine and trans on my car. I upgraded to poly engine mounts so that it would stop the exhaust banging, that pisses me off more than anything. When I pulled out the stock rubber motor mounts with 88,000 miles on them, there wasn't much left to the driver's side mount, totally shot.
However, now that I've driven with the poly mounts for while, you can definitely feel the increased vibration. You can feel it in the whole car while driving, especially in the shifter. If I had the chance to do it again though I would, I'd rather do poly mounts once and be done with it than do rubber mounts again. Not to mention the entire divetrain stays put, nothing will tear a car apart faster than a drivetrain that isn't securely mounted in the chassis.
Old 09-18-2007, 09:29 PM
Tainted's Avatar
have fun, but poly mounts are worth it in the long run
Old 09-20-2007, 09:47 PM
hammerhead's Avatar
Default PM Box
Platnum, My PM to you bounced back. Says you need to free up some space.
Later
Old 09-21-2007, 04:48 PM
LSGunZ28's Avatar
why not a trans mount? I broke min e2 months ater I bough the car, if you are gonna shift hard, get a trans mount also.
Old 09-21-2007, 04:50 PM
LSGunZ28's Avatar
nvm he wasnts rwhp
Old 09-21-2007, 06:33 PM
bitchncamaro's Avatar
Poly motor mounts are the best bang for da' buck.The motor pulls the whole damm car now , stockers are junk ...Ive installed 2 diffrent poly trans mounts, vibration from HELL past 75mph.....I'll stick with the gm stocker trans mount...
Old 09-21-2007, 06:35 PM
95 Z28's Avatar
They're not bad to do, I did mine when I did my headers, and they'll be cake for you to do with the engine out. My car has no extra vibrations from the Prothanes and I'm definitely glad I shelled out the whopping 50 something bucks for them.
Old 09-21-2007, 09:30 PM
LSGunZ28's Avatar
so youd rather break a trans mount than live with some minor vibrations?
I never even recall having a vibration.
Old 09-21-2007, 10:47 PM
mikenews's Avatar
leave trans mount stock.....otherwise it will vibrate you eyes out!
Old 09-22-2007, 08:08 AM
KRAZY K 2000 TA's Avatar
mine vibrates with the poly trans mount a little definetly the trans mount cause i switched back and forth ,as for the motor mounts definetly worth it.even though its a PITA.
Old 09-22-2007, 02:25 PM
simple's Avatar
does anyone notice a pattern in here with the poly trans mount?
Old 09-22-2007, 09:28 PM
warp10's Avatar
I did the poly mount and kind of regret it now. I should have install solid mounts. Y-pipe was fine for a few months and is starting to bang the floor board again.
Old 09-22-2007, 10:48 PM
95 Z28's Avatar
What do you mean? I did poly motor mounts when I put my headers in and never even really thought about putting a poly trans mount in at the time (didn't really know anything about them) I'm actually going to try out a poly trans mount for sure to see if it tightens things up a little bit at the track. As for living with vibrations in my car, I've got a prokit/stock shocks and dumped duals...I've become very accustomed to all sorts of uncomfortable ****
