Rear End is Humming/Whinning??
After I got home from the track a week ago, ive been hearing this humming/whinning sound coming from the rear end. It begins as I accel and doesnt stop to a decelerate. Do you think its the posi, bearings, or something else? Also the rear is completely stock with stock 3.23 gears.
Thanks,
Tom
Thanks,
Tom
how many miles on the car? It's a possibility that your bearings are bad. when was the last time you changed your rear fluid? and w what? you should have an auburn posi abd those tend to burnout as they have clutches.
I'll bet its your bearings. I had the same problem recently and the pinion teeth had broken off. Had it all fixed, quiet as a mouse now. Seems to be a common problem with these cars. Don't let it go too long without fixing as it will cost you more $$$ if you let it go too long.
Yea I think its the bearing too. Well ill save up and have the gears changed when there changing out the bearings. How much do they usually charge to change the bearings.
I paid about 850.00. That was at a dealership, parts and labor/tax.
Restricted User
I had a Dodge Dakota that had a bad pinion bearing and it sounded like loud tires going down the road. It cost me $150 labor to replace all of the bearings plus the price for the parts.
