Anyone Use The J.w. Ultra Bell?
This is true... I just did mine on Monday and all that you have to do is put the bellhousing up to the back of the block and tap it a little to get the indention (pretty much grime on the back of the block =) ... After that just take a drill and clearance those holes (3)... Put it back on and try again to see if you got exactly where it need to go... I really like mine and there's pretty good clearance... I have a 9.5" converter and there's plenty of room in there... I just wouldn't go with a stock size converter because there's not THAT much room..
