6th gear
Old 09-21-2007, 05:28 PM
99_SS_LS1's Avatar
Default 6th gear
I was just curious at what speed people use 6th gear for fuel economy? I usually use it at speeds over 55 mph unless it's hilly.
Old 09-21-2007, 05:35 PM
tpduke112's Avatar
I dont go into 6th unless I am doing 70.
Old 09-21-2007, 05:44 PM
slow1999blackz28's Avatar
I use mine at 50 but I have 4.10s before I got them I'd use 6th at around 65, 70
Old 09-21-2007, 05:52 PM
SmokinU's Avatar
What's a 6th gear? haha
Old 09-21-2007, 06:41 PM
Moderator
davered00ss's Avatar
I have 4.10's and go into 4th @ 80. 2,100rpm.
Old 09-21-2007, 06:44 PM
02 Camaro SS's Avatar
I have 4.11s and go into 6th at about 45.
Old 09-21-2007, 06:46 PM
Breaking Stuff's Avatar
3.73's. I usually go into 6th at about 55-60.
Old 09-21-2007, 06:51 PM
68birdls1's Avatar
So you drive around in 5th gear at about 2300 or so?!?
Old 09-21-2007, 07:45 PM
JScamaro's Avatar
Makes me want go buy a 6 speed
Old 09-21-2007, 07:47 PM
Jedi Master
Gh0st's Avatar
I put it in 6th at 50pmh.
Old 09-21-2007, 08:09 PM
tpduke112's Avatar
I am talking about interstate driving. When I am driving around town and I am going to be doing 60, then I am in 6th. When I am accelerating to get up to internet speed, I dont shift into 6th until 70.
Old 09-21-2007, 08:17 PM
LS1>girlfriend's Avatar
^^ internet speed . i used my Z as a modem too but then i got the roadrunner with a 440 and since then its been a whole new surf for me
Old 09-21-2007, 08:24 PM
01WS6JACKLE's Avatar
so 6th at 40 or 45 is bad for fuel economy?
Old 09-21-2007, 09:02 PM
LrngCrv's Avatar
w/ 4.11s I shift into 6th at 55 and over for cruising. But when driving my friend's SS w/ stock gears and stock cam I shifted into 6th at the same speed. I think my car just feels healthier at higher cruising rpms.
Old 09-21-2007, 09:57 PM
Vrbas's Avatar
+1
Old 09-21-2007, 10:10 PM
gmguy4life's Avatar
I think so because you are lugging the engine. I shift into 6th around 50-55 mph and the rpms is around 1500. I would not drive the car in a gear that turns the engine below 1500 rpms.
Old 09-21-2007, 10:23 PM
Mr.Powers's Avatar
I just spewed coke all over my damn keyboard...
stock 3.42's 60mph is the earliest i'll go into 6th...
Old 09-21-2007, 10:25 PM
ONEBADASSWS6's Avatar
It all depends. If you're cruising along at 1400RPM on flat ground just barely touching the throttle, and the motor has no real load on it, then its good for fuel economy.
However, if you're "lugging" the motor, meaning high gear, low RPM's, and lots of throttle, then thats bad for fuel economy and not so good for the motor either. You basically just have to balance it out.
Ideally, you want the highest gear possible with the least throttle position possible, without lugging the engine. Follow that and you should get the best fuel economy.
Old 09-21-2007, 11:57 PM
Smokin00WS6's Avatar
I start my car in 6th because of the low end torque. LS1 are bad ***.
Old 09-21-2007, 11:58 PM
^^^^^^ That was just a joke, I go to 6th at about 55 or so on thruway! 3.42's!
