How bad does this look? (PICS)
Old 09-21-2007, 05:49 PM
noxiouSS's Avatar
Default How bad does this look? (PICS)
On a scale of 1-10, 1 being why the hell did you replace It? 10 being i cant belive the car was still driving with that clutch.
Old 09-21-2007, 05:58 PM
blk99camaro's Avatar
I just pulled mine out today too and it looks almost exactly like yours. Are you going to use that same flywheel and get it turned or just get a new one? Thats my dilema.
Jon
Old 09-21-2007, 06:06 PM
noxiouSS's Avatar
Jon
i actually bought the ls7 clutch kit. So it came with the ls2 flywheel.
I would turn yours for sure.
Old 09-21-2007, 06:20 PM
crazydavez28's Avatar
that looks pretty bad to me; worse than what i pulled last night
here's my solution!!!
Old 09-21-2007, 07:15 PM
Black02SLPSS's Avatar
Thats a NICE heat glaze pattern on that pressure plate
Old 09-21-2007, 07:42 PM
CW00BlackTA's Avatar
I'd say 6-7. All of that discoloration on the PP means is slipping a lot and overheating. Resurface the flywheel until you have a uniform and clean appearance.
Old 09-22-2007, 12:44 PM
brad8266's Avatar
damn that looks bad
Old 09-22-2007, 01:17 PM
thesource's Avatar
The wear marks are almost gone on the disc and their is a lot of heat spots on the pressure plate and flywheel . It would work if you are in a pinch but I'd probably replace it if you plan on keeping the car .
Old 09-22-2007, 06:07 PM
thirdgen327's Avatar
looks like one i just pulled out. no lack of heat there!
Old 09-22-2007, 08:54 PM
_JB_'s Avatar
How many miles on are it?
Old 09-23-2007, 12:13 AM
noxiouSS's Avatar
47k
problay 20-30 1/4 passes
Old 09-23-2007, 01:03 AM
_JB_'s Avatar
Originally Posted by noxiouSS
47k
Damn, I have 20k more miles but probably 20 less 1/4 runs and my clutch looked the same as yours, but the pressure plate was not as heat soaked. Guess that shows what racing does lol
Old 09-23-2007, 11:48 AM
2KnbmTA's Avatar
haha those look almost as bad as mine. mine was so worn out that my car hardly moved. i had to dump the clutch to get anywhere, and even then it went real slow cause itd slip all the way through every gear, grabbing only slightly. felt like i had a stall lol except it didnt go anywhere
Quick Reply: How bad does this look? (PICS)
