alt. help
alt. help
I bought the shitty painless harness for a 98 camaro and i can't get my alt. to charge. i Installed a 470 ohm 1/2 watt resistor in line to term. b and still am not charging. Is there anything else i can do to get a good charge? Any help appreciated
sawzall wielding director
The easiest way to check it is to pull the alternator off and take it to one of the chain parts stores, as most of them will test it for free. If the alternator tests ok then it is the wiring. How exactly did you wire the resistor in? Did you use the painless harness at all or did you hook one end of the resistor to the alt and the other to a wire that is IGN + ( has + 12v when the ignition is in the run position).
