Solid motor mounts?
Originally Posted by brandonppr
Tubular "LSX" Solid Motor Mounts
Item: 992
$145.00
1998 - 2002 GM F-Body » Chassis » Tubular "LSX" Solid Motor Mounts
Item: 992
$145.00
yeah those are what I was looking at but they bolt to the K-member side(to replace the stock k-member stands). you still have to use your clamshell mounts on the motor side and that what I want to get rid of. I can't seem to find anyone that makes them for LS cars(Moroso makes them for LT cars). Looks like I will just switch to poly ones and live with it for now.
You can see them on my car:
I think your thinking about the "Lightweight "LSX" Motor Mount Bushing Stands" Which just holds the bushing then the bushing mounts to the engine
Originally Posted by tektrans
Can you run solid mounts for a street driven car?
They don't recomend running a solid trans mount with the solid motor mounts. I run the poly trans mount.
It helps keep the exhaust form moving around as much.
Race your car!
at 900 hp I would definately put a motor plate on it. get much more then that and I'd do a midplate as well.
fwiw I am going to put a motorplate on my car in the very near future, not because I am having a problem, more for making doing the k member and a arms with the motor in the car over the winter alot easier, plus it will make future changes/plans alot easier as well.
No, those are the exact ones I got. They bolt strait to the engine and k member. There is nothing in between.
Your right that is what I was looking at. But these will also not work with my BMR K-member. It has a welded stand that the clamshell bolts to.
