Drag Racing Tech
Solid motor mounts?
Old Sep 21, 2007 | 09:46 PM
Badmire68's Avatar
Default Solid motor mounts?
Who runs them and what brand are the best?
Old Sep 21, 2007 | 10:21 PM
vtec's Avatar
Resident Racing Jerk
i run them. moroso for me, donno for you.
what are you doing, building a racecar or something?
Old Sep 21, 2007 | 11:06 PM
brandonppr's Avatar
spohn here
Old Sep 22, 2007 | 05:09 AM
JL ws-6's Avatar
Race your car!
put a motor plate to it, best solid motor mount you can do
Old Sep 22, 2007 | 05:14 AM
JMBLOWNWS6's Avatar
I have the prothane from summit. They work like a champ!
Old Sep 22, 2007 | 01:27 PM
Badmire68's Avatar
what is the part number for the spohn? the only thing I could find on there website is the k-member side to use with the rubber/poly motor side.
Old Sep 22, 2007 | 01:49 PM
brandonppr's Avatar
Tubular "LSX" Solid Motor Mounts
Item: 992
$145.00
1998 - 2002 GM F-Body » Chassis » Tubular "LSX" Solid Motor Mounts
Old Sep 22, 2007 | 02:09 PM
Top Fuel's Avatar
spohn here, much better feel than stock
Old Sep 22, 2007 | 02:35 PM
Taubr Unit's Avatar
i got poly ones and they are damn stiff. But i thinking about soilds.... humm...
Old Sep 23, 2007 | 09:47 AM
Badmire68's Avatar
Item: 992
$145.00
yeah those are what I was looking at but they bolt to the K-member side(to replace the stock k-member stands). you still have to use your clamshell mounts on the motor side and that what I want to get rid of. I can't seem to find anyone that makes them for LS cars(Moroso makes them for LT cars). Looks like I will just switch to poly ones and live with it for now.
Old Sep 23, 2007 | 10:02 AM
brandonppr's Avatar
No, those are the exact ones I got. They bolt strait to the engine and k member. There is nothing in between.
You can see them on my car:
I think your thinking about the "Lightweight "LSX" Motor Mount Bushing Stands" Which just holds the bushing then the bushing mounts to the engine
Old Sep 23, 2007 | 10:36 AM
tektrans's Avatar
Can you run solid mounts for a street driven car?
Old Sep 23, 2007 | 10:40 AM
ls1408cp's Avatar
does anyone use solids on say a 900hp app.
Old Sep 23, 2007 | 11:23 AM
brandonppr's Avatar
I don't see why not. If your car is really quiet you might get a little more vibration but I can't tell as mine is loud anyway.
They don't recomend running a solid trans mount with the solid motor mounts. I run the poly trans mount.
It helps keep the exhaust form moving around as much.
Old Sep 23, 2007 | 11:24 AM
brandonppr's Avatar
I don't know about that much. I would feel safer with a motor plate at that level.
Old Sep 23, 2007 | 11:47 AM
JL ws-6's Avatar
Race your car!
at 900 hp I would definately put a motor plate on it. get much more then that and I'd do a midplate as well.
fwiw I am going to put a motorplate on my car in the very near future, not because I am having a problem, more for making doing the k member and a arms with the motor in the car over the winter alot easier, plus it will make future changes/plans alot easier as well.
Old Sep 23, 2007 | 11:55 AM
DEVIATE's Avatar
Who makes a motor plate for our cars. (ls1)
Old Sep 23, 2007 | 12:43 PM
Badmire68's Avatar
Your right that is what I was looking at. But these will also not work with my BMR K-member. It has a welded stand that the clamshell bolts to.
Old Sep 23, 2007 | 04:36 PM
JL ws-6's Avatar
Race your car!
madman
Old Sep 23, 2007 | 07:08 PM
brandonppr's Avatar
OK so you will need the type that bolt to the engine then has a pin conecting the two mounts together. I would give BMR a call about that. I have seen them but I don't know which would be compatible.
