New LS1 Owners - Newbie Tech - 400+ rwph club please sign and list mods...
slowjoe99
09-22-2007, 06:00 AM
Got 400+ hp at the wheels? List below with mods... :cool:
mohammed_k81
09-22-2007, 08:20 AM
My Ride Spec Camaro Z28 Smoke Silver
Header Long System borla Air system Ls6 intake Asp pully Gx5 custom cam Patriot Performance LS6 5.7L Stage II Head Assy
(2.02/1.60/59cc) SPEC Clutch Kit Stage 3+
Meziere Electric Water Pump Dyno Tune
Rwhp 467
Benjamin Russick
09-22-2007, 09:52 AM
2000 Z28 with 383, nitrous and supporting mods.
HASTINGSRJ
09-22-2007, 10:44 AM
check sig
NVR KNO
09-22-2007, 11:25 AM
99 SS M6 Lid/Longtubes/Dual Cutouts/12 bolt/3.73s/Spray
350/360 motor
4xx/5xx 100 shot
Blake01SS
09-22-2007, 11:45 AM
2001 SS...Full Exhaust/LS6 Intake/Procharger P-1 @ 7lbs...
Stock 4L60E
Stock Longblock
Stock 10 Bolt
Made 421 rwhp and 461 ft lbs...
Have a little more than that now but Havent been back to the dyno...
99FormulaM6
09-22-2007, 11:53 AM
99 Formula
224 Cam
TSP Ported 243 heads
Hooker Headers
Lanes True Duals
was 375 before heads...havent had it tuned yet, but im over 400 :)
ChevyWeatherman
09-22-2007, 12:08 PM
412 cam only. Mods in sig (link).
LrngCrv
09-22-2007, 05:31 PM
419 rwhp
Custom Cam, Lid, LTs, TDs, tune (stock heads)
5_02ls1
09-22-2007, 07:16 PM
havent been to a dyno but if this ones not over 400 none are.....
long tubes/3" x pipe true dual setup/weiand intake p&p throttlebody/lid/vinci crane cam/n20 tune/150 shot......
AncientRgn
09-22-2007, 07:26 PM
All I have is a Type R sticker. 446hp :lol:
MetallicaMatt
09-22-2007, 07:29 PM
402rwhp N/A
mods in sig
black01_WS6
09-23-2007, 04:08 PM
numbers in sig. and mods.
99camarosupersport
09-23-2007, 04:12 PM
a blowdryer and lots of shiny piping. forged ls6.
don't know numbers with boost, put down 362 n/a i'm pretty sure it's over 400 though now. :lol:
Thule
09-23-2007, 07:46 PM
just installed this bad boy
99+ style cylinder block, brand new
clevite performance main bearings
clevite performance crankshaft bearings
clevite perfect circle piston rings
KATECH rod bolts
KATECH head studs
LS6 ported oil pump
LS2 time gear/chain
patriot StageII heads 59cc
ferra valves (2.02/1.60)
extreme lift double springs
Harland sharp roller rockers, 1.7 shaft mounted
Comp cam chromoly push rods, 7'400
ls7 lifters
patriot 226/226 585.585 112LSA cam
FAST 90mm intake
N.W 90mm throttle body
FAST billet fuel rail kitt,
FAST fuel line adapter kit,
FAST fuel pressure gauge
GM/DELPHI 85mm ls2 MAF dumped the screan
Pacesetter ceramic coated Long tubes,
Pacesetter off road Y pipe
SLP Loudmouth1 catback
LS7 clutch kit
LS7 flywheel
160° thermo
knock sensor modd, (02style)
colant crossover pipe's from byunspeed
no dynos yet.. but if it isn't over 400rwhp.. i will not be.. happy
bin driving it.. and its promising :D wheelspin in 3rd
geeteego
09-23-2007, 08:08 PM
'04 Goat
STS T76GTS Turbo (currently @ 5psi)
Comp cam
JBA mids
Stock heads/hardened pushrods/Patriot Gold Valvesprings
SLP UDP
160 thermo
HP Tuners
c5formula
09-23-2007, 08:12 PM
bolt on lt1 with le2 package, 420rwhp 385rwtq
7th Darkness
09-23-2007, 08:13 PM
Check Sig
99camarosupersport
09-23-2007, 08:43 PM
'04 Goat
Comp cam
JBA mids
SLP UDP
160 thermo
HP Tuners
that car looks beautiful
hardtopz28
09-23-2007, 09:29 PM
check the sig minus the asp pulley and the bo white you will have 401 :burn:
LSWon00
09-23-2007, 09:39 PM
LTs, cat-back, 3400 stall (not a power mod :) ) LS6 intake, ported TB,
224/228 .585/.585 114 Cam Motion, 100hp wet N20
duckman9898
09-23-2007, 10:55 PM
01 ta ws6 it volant air box, 90mm fast intake and throtle body, pacestter long tubes, slp loud mouth exaust, brent bower custom cam sorry no numbers, dart heads, 12 bolt
435rwhp/ 467rwtq
thislswon
09-23-2007, 10:57 PM
never been to the dybo...but on 125 shot i should be in the club and my mods are in signature below
