how much power am i losing?
True, I cant gve a number, But its not lik you have a fast 90 intake, so it may not be that much. The dyno guys said that you would pick up 15 rwhp with a fast 90/90 combo over an ls6 intake/ stock TB. That was with my cam only motor so maybe you would get 20 outof it at most. Having sad that, 5 RWHP sounds good. 10 would be great.
might as well just save up and get the 90/90 combo when you can instead of throwing money at the stocker because that will give you some good power and you will need it or should I say, it would really help if you add anything else to the car. After doing heads and cam, it is a good time for the 90/90 setup but when is it never a good time to install new parts....
