How I fixed my banging y-pipe for free. BIG PICS
Old 09-24-2007, 10:39 AM
snketr's Avatar
Default How I fixed my banging y-pipe for free. BIG PICS
I've done this to a couple cars now and it's worked every time. I've got $0 in this, but you may spend a couple bucks if you don't have a welder or some sort of paint at the end.
First pic is stock and you can see the minimal clearance betweeen the floor and exhaust, I had less than 3/4"
Next I took my cutoff wheel and made two cuts along the floor board where the drivers exhaust pipe runs.
Now with the floor cut, I took a hammer and hammered it down to create more clearance. I had to use a 6lb sludge for some of it. BE CAREFULL NOT TO HIT YOUR FUEL LINES WITH THE HAMMER.
Once it was hammered flatter I hit the sided in to match the center and took my welder and welded up the 2 cuts and then used Rubberized Underbody Spray Coating to seal it back up.
Here you can now see the extra clearance. I gained about 2"
Yes, my welding isn't the best, but it works.
Took me less than an hour to do and no more banging y-pipe and no extra vibrations from having to do poly mounts. My car vibes enough from the cam.
Old 09-24-2007, 10:57 AM
COD02SS's Avatar
I sure hope that's not a structural part of the body
Old 09-24-2007, 11:39 AM
tripps's Avatar
I like the innovative approach, but I just can't see myself cutting slashes in my car. Poly motor mounts worked fine for me.
Old 09-24-2007, 11:47 AM
snketr's Avatar
It's still plenty strong for holding up the floor. That's about all it does.
Old 09-24-2007, 12:59 PM
teke184's Avatar
$60 poly motor mounts >>>>> hacking up your uni-body
that's all i'm gonna say
and i felt NO increase in vibration after my mounts....and that's with a cam too
Old 09-24-2007, 02:17 PM
xBROKEx's Avatar
or you could just buy headers that fit
Old 09-24-2007, 02:18 PM
snketr's Avatar
Do you guys not realize it's an f-body. They are a dime a dozen and not exclusive.
Old 09-24-2007, 02:19 PM
snketr's Avatar
You are clueless.
Old 09-24-2007, 02:31 PM
Soul TKR's Avatar
at all the negative comments and the poster getting pissed....
I give you thumbs up and props on the new ideas and guts to do it, but cutting into a car like that is something that I personally couldn't do, as I'd be scared of structural integrity. If it works, and doesn't bother you or hurt your car KUDOS!
Old 09-24-2007, 02:34 PM
snketr's Avatar
I'm not getting pissed. I just think it's funny that some people think these cars are precious. I just have a different state of mind on these things.
I posted to help others who may want a cheaper alternative.
Old 09-24-2007, 02:37 PM
89Formulaws6's Avatar
i did this on my old g-body, some people just hit the crossmember with a sledge instead of cutting it.
never would do it to my f-body tho
Old 09-24-2007, 05:10 PM
Mike94ZLT1's Avatar
Wow... You would actually rather cut a structural part of the car than flatten a pipe a little bit... I'm sorry but this is one of the stupidest things I've ever seen on this site. Or any of the other car sites I am a regular on.
Old 09-24-2007, 05:21 PM
litle88's Avatar
I had banging and I just purchased the mufflex antibanging hanger and the Pace ORY pipe(which is kinda ovalized on that section) and I dont bang anymore!
Sorry but its not that I think it is precious, I just take pride in the work I will be doing on my toyz! but to each his own.
Old 09-24-2007, 05:34 PM
djsanchez2's Avatar
Cool. I did the same thing w/o all the cutting/welding. Just hit a few good times with a mini 6lb. sledge. Did the job in less than 2mins.
Old 09-24-2007, 09:52 PM
5_02ls1's Avatar
wow I thought this was gonna be another rubber snubber thread wow......i didnt cut my sub frame but i did take a big ole ****** hammer to it......no banging at all now on thenew x setup.....
Old 09-25-2007, 08:14 AM
RacerScott's Avatar
yikes
Old 09-25-2007, 10:38 AM
wowsers's Avatar
wow, you solved the problem
Old 09-25-2007, 11:07 PM
Full-Force's Avatar
Thats not exactly a new idea. I have been doing the same thing for 2 years now on everybodies car I work on. The only difference is that I just cut that plate completely out right there. Its not a big deal, and its not hurting the structure of the car.
You dont gain more than 1/2" though if you have longtubes. With longtubes a straight piece of 3" pipe will be rubbing right on that spot on the body, and that piece only hangs down about 1/2". You still have the fuel lines right there also so you cant get the pipe but so high.
Old 09-26-2007, 12:19 AM
chromeplated500's Avatar
Nice job... I'm looking into what I'm gonna have to do... and anyways its not gonna hurt the structure just dont go pullin a boat around.. lol that would be a bitch to weld.. nice job.
Old 09-26-2007, 07:01 AM
teke184's Avatar
"I'm not getting pissed. I just think it's funny that some people think these cars are precious."
i'm sorry....generally anything i pay $15,000 for....over the course of 5yrs....i consider pretty precious.
glad you have disposable income
Quick Reply: How I fixed my banging y-pipe for free. BIG PICS
