Drag Racing Tech
Suspension Experts - Why does the rearend do this?
Old 09-24-2007, 11:56 PM
chuckyt1's Avatar
Default Suspension Experts - Why does the rearend do this?
This ended up being a 2.5 60'. In the vid, you can see the rear hit the tires hard and then they hop back up and break loose.
28" MT Streets at 18 PSI, QA1's with the fronts at 1 and the rears at 6. Ran a 1.56 the same night with a bog launch. Thinking about going to a pure slick to see if that will fix it.
http://www.fquick.com/videos/Wheel_Hop/3249
Old 09-25-2007, 12:54 AM
daniel6718's Avatar
they arent hooking at all...either tire pressure too high dumping clutch too high...lca angle off something
thats not hooking then ho[[ing up and breaking loose thats not hooking period..what are you dumping clutch at? what gears?
Old 09-25-2007, 06:21 AM
tektrans's Avatar
You have no weight transfer whatsoever. Start w/ the stickier tire and from looking at the pic in your sig the front of your car is too low.
Old 09-25-2007, 01:37 PM
94z28L's Avatar
what all suspension is exactly done? have you played with the rear shocks at all? almost looked like the rears weren't stiff enough, above posted definately has it with no weight transfer
Old 09-25-2007, 07:42 PM
chuckyt1's Avatar
I need to change that pic in my sig. I took that right after I put the QA1's on just cuz it looked cool. Then I raised the front end up to where it should be.
Even tho it looks like it didn't hook at all, when I look at the vid in slow mo, I can see the rear wheel go down a couple of inches. Then, when the tires hit, it comes back up, goes down one more time, and then blows the tires off.
As for suspension - Spohn tunnel mount adj TA, (-2 on the pinion), UMI adj LCA's with relo brackets, (bottom hole), BMR adj panhard, Spohn drag rear sway bar, 275# springs, front sway removed and a 9 inch with 4.10's. SA QA1's with "R" series on the front.
I need to figure out why the rearend hops back up into the car on high rev launches
Here's a vid of the same night, same setup, and a 4.5k launch as opposed to 5.5k
http://www.fquick.com/videos/Launch/3241
Old 09-25-2007, 10:01 PM
promod1955's Avatar
what shocks are you running on the rear?
Old 09-25-2007, 10:08 PM
chuckyt1's Avatar
QA1 SA's set on 5 - 6
Old 09-25-2007, 10:24 PM
LS1curious's Avatar
did you forget to put the rear shocks in ? If not try some LCA brackets ? How about rear springs ?
Old 09-25-2007, 10:27 PM
01FbTaWs6's Avatar
try easing out that clutch, dont just DROP that ****.
Old 09-25-2007, 10:49 PM
chuckyt1's Avatar
Pretty sure I put em in but I'll double check tomorrow. It's got LCA relocation brackets on it set on the bottom hole...
Old 09-25-2007, 10:50 PM
daniel6718's Avatar
ok you neeed to quit trying to rev up while dumping clutch....looks like you in the right area for 4500 or so...id try holding it at around 5k and slip the clutch quickly and then leaning into the gas...guy with the worlds fastest stock z06 has a big writeup on how to launch a stick
Old 09-25-2007, 10:51 PM
daniel6718's Avatar
http://www.rangeracceleration.com/Launch_Tips.html
Old 09-25-2007, 11:05 PM
chuckyt1's Avatar
Originally Posted by daniel6718
Thanks. Funny, I just sent another member to Rangers sight a couple of days ago. Need to practice what I preach, I guess.
Still want to know why that rear end jumps back up. If I could launch at a little higher rpm, and keep the rear end planted, I could get that 60' down to the low 1.5's or high 1.4's.
Old 09-26-2007, 08:26 AM
Bitemark46's Avatar
+1. Car has no added load to the rear tires. To the OP, I assume the sway if off the car right? Just making sure. -Mark
Old 09-26-2007, 10:02 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Not enuff information....
-rear tire psi
-rear tire size
-best 60 ft ever in the car
-what are front shocks at
-what are rear shocks at
-are they QA1 r's or the other ones
Old 09-26-2007, 11:30 AM
chuckyt1's Avatar
Hey John,
The 1.56 was the best so far. It'll do 1.6's all night long.
I was going to go tonight, and work on it, but it looks like a Harley Shootout. Might be crowded..
Chuck
