th400 in 2000 Trans Am
BMR conversion crossmemember with torque arm mount and a custom driveshaft. Not sure what you need to do to mount the tranny to your LS block though. You can use your stock shifter, it just wont go into 1. Also you will need to convert the tranny to use an electric speed sensor, you could buy the VDO adapter to get your speedo to work but you will loose cruise controll and ABS. If your going to convert the tranny I would recomend doing it before you install it.
