low oil pressure
god i dunno but im about to switch to mobil one. i didnt do the last oil change. it just seemed low. i had a few problems so i was checking. the first one was i had that spout that came off the valve cover like 4 inches up with the cap on it, and that snapped off, so i just screwed the oil cap on the the valve cover, and thesecond was when i dropped the tranny for the clutch, i noticed the rear of the oil pan was homemade silicone gasket all the way and there was some oil on it. so i had to remede that before i got oil on a new clutch. just making sure my oil pressure was ok. thanks
if you are that worried do a compression test dry/wet as long as you are over 110 for all and they are within 25 of each other id say ur good..
thats the real way the gauge in car is basicaly is the car running or not running I dont trust it much if your trying to get real technical with it
i just got 5w 30 in tehre today, did a fresh oil change. i havent checked the guage WOT it goes up, but other than that not much more than 20-40
