ls6 or fast 90 combo on stock motor
Old 09-29-2007, 02:30 PM
99T-Top Z28's Avatar
Default ls6 or fast 90 combo on stock motor
I have a 408 motor that I was going to put into my corvette but have later decided to do a turbo setup in my vette. I have a fast 90 combo and was wondering if I could just put it on my stock motor and notice any decent gains or if I should buy a ls6 intake until I decide to go all out on motor. I haven't seen much saying that the fast won't work..just that it wont really outperform the ls6 on a stock motor. So question is, should I buy an ls6 or would I be fine just putting the fast 90 intake and tb on the motor for a few months until I buy the turbo setup.
Old 09-29-2007, 02:34 PM
Tainted's Avatar
if you have the FAST 90 already go for it, especially if you plan on gonig with a larger more powerful motor in the future.
the FAST 90 will give more power than the LS6 on a stock motor - just not where you can use it, say high up in the rpm's.
Old 09-29-2007, 02:35 PM
TheLS1Kid's Avatar
It is overkill on a stock motor, but since you already have it I'd just put it on to save yourself from spending $350 on an LS6 intake that you will be taking off in a few months.
Old 09-29-2007, 02:39 PM
So won't do much for me over an ls6 but should give me heaps over an ls1?
Will the Fast be a great improvement for use with a TT setup running stock bottom psi like 6 or 8 max. What if I use nitrous? With the fast, will it help out much on the stock motor?
Old 09-29-2007, 03:15 PM
Tainted's Avatar
yes it will be worlds better than the ls6 intake. it will be a very nice improvement for a TT motor and running nitrous as well. However, most people use a metal intake for turbo set ups but sicne you arent running a lot of boost you should be fine
Old 09-29-2007, 06:00 PM
Thanks I will prolly install it tonight because Friday I have an appointment at carolina auto masters in NC for a dyno tune.
Old 09-30-2007, 04:20 AM
chefman's_TA's Avatar
90/90 is the big cheese when it comes to lsx intakes.. go for it.
Old 09-30-2007, 06:47 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Originally Posted by 99T-Top Z28
Will the Fast be a great improvement for use with a TT setup running stock bottom psi like 6 or 8 max. With the fast, will it help out much on the stock motor?
Most people on the F.I. section will be running the LS6 intake. You won't find many using the Fast 90.
Old 09-30-2007, 08:00 AM
02silvaZ's Avatar
fast 90 is good but as said, useless on a stock motor for useable power, just alotta upper end power, now when you are done with your build up it will be very beneficial
Old 09-30-2007, 08:28 AM
So, are you saying it won't be an improvement over an ls1 intake on a stock motor?
Old 09-30-2007, 04:20 PM
Anyone else?
Old 09-30-2007, 08:54 PM
TheLS1Kid's Avatar
It will definitely be an improvement over an LS1 intake on a stock motor.
Old 10-03-2007, 09:44 PM
Thanks
