New 5 Layer GM Head Gasket's Result's!
Old 10-02-2007, 06:16 PM
HUNTER02SS's Avatar
Default New 5 Layer GM Head Gasket's Result's!
To start I have a set of Dartt225's with o-ring's. I purchased a set of the new GM 5 layer gasket's as did Cablebandit and they are completly flat! i went ahead and and installed them with my head's. I asked a bunch of people if they would work and some said yes and some said no,and some havn't even seen them yet! If the gasket was designed any different I would not have installed them,but the top metal gasket is paper thin and under neath that it is recessed just as the old 3 layer gasket is. Anyway, The car is running and no leak's and I am letting it cool down to retorque them and then I will get into some boost with it and find out if they will work or not?So far so good!
Old 10-02-2007, 06:27 PM
99Z28LS1's Avatar
i hope it works out for you bro
PS, you have a bad *** ride and awesome videos too
Old 10-02-2007, 08:10 PM
cablebandit's Avatar
I got the gaskets but no heads till friday
I hope they work for us both!!!!!!!!!!
Old 10-02-2007, 08:15 PM
02SSLE's Avatar
cool I bought some Felpro 1161's that's what ETP told me to run.
Old 10-02-2007, 08:27 PM
HUNTER02SS's Avatar
I seen your pic's of the new awesome head's you recieved!! That is my Christmas present this year!
Old 10-02-2007, 11:21 PM
frcefed98's Avatar
man I hope they hold up....see if you can push it to the 2x psi range
Old 10-03-2007, 09:29 PM
HUNTER02SS's Avatar
Well, I took the car on a drive for about 6 or so mile's down the interstate! The results: No leaking Water or pushing water as of yet!I did about 3 second gear pull's and then about 3 or so 3rd gear pull's shifting into 4th. and so far so good!!!!Still at 18lbs. so all I am hoping is it get's me through this weekend at mississippi!!! I will keep you posted as the more mile's I put on it!
Old 10-03-2007, 10:50 PM
njc.corp's Avatar
sounds good-
Old 10-04-2007, 01:23 AM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
What gaskets were you using that pushed water?
Thanks
Old 10-04-2007, 02:44 AM
Rickys S/C Z28's Avatar
good luck man cant wait to see what happends
Old 10-04-2007, 08:06 AM
HUNTER02SS's Avatar
Thanks
The stock gm 3 layer mls gasket's!
Old 10-04-2007, 08:34 AM
rjw
rjw's Avatar
Thanks
Anyone try the Cometics with these heads?
Old 10-04-2007, 08:51 AM
with Darts?
Old 10-04-2007, 09:00 AM
speedracer5532's Avatar
Thanks
I have ran .040 Cometics with AFR 225 heads with 18 lbs of boost with L-19 head studs and I need to change my gaskets now because I am pushing some water out the over flow when running it hard. I have a set of these 5 layer GM gaskets that I am going to try. I really want a set of the Fel-Pro 6 layer gaskets.
Old 10-04-2007, 09:14 AM
MIGHTYMOUSE's Avatar
sounds fairly different from my fel pros.. why not post a photo???
Old 10-04-2007, 09:39 AM
HUNTER02SS's Avatar
MM, Cablebandit started another thread on the new gm gasket's and has some pic' posted! Damn, pushing water with afr head's! I only pushed water this last time because i was hot lapping it at the track. Other than that it was ok.
7 Second Club
NicD's Avatar
What is the bore of the new gm 5 layer gaskets? I thought the AFR 225s required a very large bore gasket, larger than the gm 5 layer ones?
Old 10-04-2007, 09:40 AM
HUNTER02SS's Avatar
I think they are 4.100 bore.6.2 litre
Old 10-04-2007, 09:46 AM
7 Second Club
NicD's Avatar
I think the AFR 225s require a gasket with a minimum bore of 4.135, so not sure the new GM 5 layer gaskets would work in that case unless it's close enough?
Old 10-04-2007, 10:03 AM
HUNTER02SS's Avatar
I think there is a bunch of people using the 6ltr. MLS gasket on the AFR's! KP is one if them I believe?
Quick Reply: New 5 Layer GM Head Gasket's Result's!
