what is the best clutch kit for under $300?
Old 10-04-2007, 05:48 AM
LT1Falcon's Avatar
Default what is the best clutch kit for under $300?
like the title says
Old 10-04-2007, 07:42 AM
transamws6_97's Avatar
there are no good ones under 300
Old 10-04-2007, 08:04 AM
92LT1RS's Avatar
doesn't exist
Old 10-04-2007, 11:20 AM
1slowZinthe513's Avatar
are the lt1 t56s and ls1 t56s compatible?
https://ls1tech.com/forums/lsx-parts-sale/793026-f-s-spec-stage-3-6-puck-clutch-bulldog-flywheel.html
Old 10-04-2007, 11:44 AM
Mojave's Avatar
https://ls1tech.com/forums/showthread.php?t=793026
No. They use a completely different clutch setup (LT1 is pull type, LS1 is push type), and the flywheels are different too.
Old 10-04-2007, 11:49 AM
damn and it looked like such a sweet deal
Old 10-04-2007, 12:45 PM
AR15 guy's Avatar
My brother is running a RAM HD. Seems good so far. I don't think it was much more than 300$. Maybe 340$ish.
Old 10-04-2007, 12:52 PM
Hot94Z28's Avatar
This might help. http://www.ws6project.com/user_stor/...f74101a8e353b7
Also it is a bit more that 340 for a a RAM HD.
Old 10-04-2007, 12:54 PM
kinglt-1's Avatar
By a good clutch and save yourself headaches. A cheap clutch you will have to change
2:1 over a good clutch. Go with a spec.
Old 10-04-2007, 12:55 PM
kinglt-1's Avatar
Ram HD is 579.00 in jegs!
Old 10-04-2007, 01:02 PM
Hot94Z28's Avatar
Its for sale for $544 on WS6store. I have heard of problem's with spec clutches.
Old 10-04-2007, 01:17 PM
kinglt-1's Avatar
You have heard or experienced. I hear bull **** all day long that I dont believe. My spec has worked flawless for 3yrs and so has my friend that has a spec 3+ on his ls-1 D1 setup makin 650whp. The only problem with spec is people dont have the patience to break them in properly. The first couple hundred miles they dont like to be slipped. Most guys expect them to be like stock and slip the **** out of them and ruin them. After the couple hundred miles they smooth out just like a stocker.
Old 10-04-2007, 01:45 PM
Hot94Z28's Avatar
They have had there problems:
https://ls1tech.com/forums/showthrea...ch#post7816954
https://ls1tech.com/forums/showthrea...ch#post3971855
Old 10-04-2007, 01:53 PM
AR15 guy's Avatar
Ok he has a ram clutch of some sort that was around 350$ for the kit. Not sure what it is.
Old 10-04-2007, 02:01 PM
kinglt-1's Avatar
Yea and i bet bet other brands have done the same thing. Two threads dont tell me ****. There are unanswered questions to both of these threads. When you start making more power the chances of things breaking go up. Im not defending spec. This forum can be like a soap opera, a couple guys have issues and all of a sudden its the parts fault and everybody jumps on the band wagon. I was just stating I've had good luck with spec and so has everybody I know that runs one.
Old 10-04-2007, 03:26 PM
LT1Falcon's Avatar
this is all good information, i might end up going with the Ram HDX
Old 10-04-2007, 03:30 PM
rasputin's Avatar
LT4 PP + Mcleoud Single Disk. Puts you over $300, but you have to be realistic
Old 10-04-2007, 03:44 PM
HDX and OEM replacement are JUNK! Do not get low end stuff. It'll end up costing you way more. I have a spec 2 and am very satisfied. I also know people that have the higher end Ram clutches which worked good but the HDX is complete crap
Old 10-04-2007, 04:01 PM
LT1Falcon's Avatar
ok guys, but you have to understand that im making about stock power and am not looking for the best thing out there. i was considering a Zoom kit for 255 dollars. i am also trying to avoid any kit that is gonna give me a stiffer pedal than needed. i want something thats gonna be fun to drive and not give my left leg a workout. thats why i am looking into something low end and almost a stock replacement, thats why i say $300. i wouldnt mind going a little higher but definitly under 400
Old 10-04-2007, 04:04 PM
speed_demon24's Avatar
No complaints with my mcleod single disk, it was holding over 500/550 to the wheels without any problems.
Quick Reply: what is the best clutch kit for under $300?
