New LT1 Intake
New LT1 Intake
Our shop is developing a new LT1 intake manifold based off of the LS1. If you guys have any opinions or suggestions, let them fly. We should have a prototype by early spring'08.
if you make it and it has enough plenum volume for the n/a guys to make over 650 or 700 without the cost of sheetmetal would be great...if you could consider the difficulty of making it/cost while doing it and save money on final product is always good
also is this going to be composite also?
We are leaning towards composite. Just worried about it cracking from torque. But, yeah the edelbrock air crap is the main motivation behind this. 5hp for $400 is just insulting.
I mentioned awhile back if there was a way to make an LS1 intake style for the LT1!
+1 for it. +1 for composite to keep heat down.
However, it better be in the $400 range.
This would truly confuse so many people running this intake on an LTx LOL
I'm looking forwards to some concept pictures (sketches or real)
There's gotta be a way, to design a composite intake for an LT1, and not having to worry about it cracking from torque..GM did it with the LS1..Any similarities there, that you can see that would help you??
one thing i would be concerned about is hot oil on the bottom of the composite manifold. the LSx has a valley cover that bolts to the block so no oil touches it(except the PCV oil which isnt much. other wise i would consider it
