fast 78mm or 90/90
Old 10-06-2007, 06:13 PM
little_chewy_69's Avatar
Default fast 78mm or 90/90
hey guys was going to finally get an intake for my car and was wondering if i could get away with running just the 78mm fast intake with factory tb or if i should just buy the 90/90 setup it's be a lot cheaper that's the reason im asking. have the trak cam in it so i dunno if 78mm will suffice plz state your opinions.
thanks.
Old 10-06-2007, 06:35 PM
brad8266's Avatar
With the cam I would even bother with the 78, save for a 90/90, you can get the 90 intake for 700-750 shipped brand new from some places, look around.
Old 10-07-2007, 06:43 PM
well it's the TB you have to buy in order to use it that makes me not wanna buy it and i haven't heard anything about the N.W. TB so i feel uncomfortable about buying it.
Old 10-07-2007, 07:35 PM
matt94z's Avatar
I'd have a Fast 90 intake with the Fast 90 tb and love it. I installed it last week and have had no problems from my tb (everyone made me leery of buying it) it drives stock with no sticking at all. Drives like the stock tb. Now I just wish I had all my parts for my cam swap...
Old 10-07-2007, 09:04 PM
RedRallyeZ's Avatar
texas speed has a less expensive alternative that has been getting good reviews against the other 90mm tbs, its called a ptm, look for it on their site
Old 10-07-2007, 10:20 PM
do i need to buy the coolant crossover pipes and plugs if i was to put this intake on and does it eliminate the egr.
Old 10-08-2007, 09:56 AM
radkon's Avatar
The FAST 90 offers very little over the FAST 78 in my opinion and research says its overkill on a stock displacement engine. I got the FAST 78 cheap (less than $200 used) and got my TB ported and polished ($75) and am very happy with the results for the coin I spent.
Old 10-08-2007, 10:22 AM
Brads LS1 02Z's Avatar
look around on the site and you will see nothing but good about his throttle bodys all over the site... i just got one of his new black ones about to put on my car... and it looks badass
Old 10-08-2007, 10:48 AM
Restricted User
Zero4488's Avatar
90/90...I wouldn't waste my time with the 78mm
Old 10-08-2007, 10:53 AM
RedRallyeZ's Avatar
1. yes, i have never seen the alternative "grind down the ribs" method work on fasts
2. yes, can be modified for egr though. but if your going FAST, why have egr unless you have a sniffer test
Old 10-08-2007, 11:43 AM
matt94z's Avatar
You will need 01+ coolant pipes. You could grind down a LS6 intake, but the Fast bottom is smooth. You can also keep your egr.
Old 10-08-2007, 12:33 PM
Galen's Avatar
I have the PTM throttle body on my Fast 90/90 setup from TSP. So far, it works great. As far as cross over tubes, I had lost my LS6 front tube, so I just brazed off the front tube from a LS1. No problems at all. If you do go 90mm, I highly recommend the lid from Fast Toys with a 90mm opening.
[IMG][/IMG]
Old 10-08-2007, 12:40 PM
Moderator
davered00ss's Avatar
Stick with the ls6 unless you go 90/90. I only did the FAST 78 because it was free.
Old 10-08-2007, 12:42 PM
SSwt00SS's Avatar
go FAST 90/90, port the bitch and dont look back!!!
Old 10-08-2007, 02:06 PM
radkon's Avatar
3~5 HP between the FAST 78 and FAST 90
https://ls1tech.com/forums/generation-iii-external-engine/742130-fast-78-fast-90-a.html
Here is a comparison of LS intakes (no FAST 78 though)
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
http://www.vetteweb.com/tech/vemp_06...o_testing.html
Old 10-13-2007, 03:52 PM
well i think 90/90 is my final choice. a local guy i know gained 39rwhp goin from ls6 to a 90/90 with a smaller cam than i have. and may be putting heads or doing a stroker kit this winter so i think it's a better choice thanks for the info.
Old 10-13-2007, 04:12 PM
The Black Mamba's Avatar
Don't get the 78!
Old 10-14-2007, 12:39 AM
lgobraves's Avatar
78 is good if you get a real good deal on it...aka price of an ls6 intake
Old 10-14-2007, 08:05 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Keep saving and get the 90/90 and save a little more and get the intake ported by either Vengeance or Tony Mamo. Face it, we all want more power and we're never satisfied. So by buying a 78mm intake, you are leaving future power on the table. Save some future mod money and go straight to the ported FAST 90/90 combo and that way you won't ever worry about the intake/throttle body being a restriction.
Just like posted above, get a Fast Toys 85 mm intake lid, get rid of the MAF and now you have a direct flow the manifold and you would see a definite gain over the 78mm manifold.
Old 10-14-2007, 08:15 AM
Was his ported?
