Where to get a schrader valve cap...
Old 10-07-2007, 07:58 PM
blind527's Avatar
Default Where to get a schrader valve cap...
Does anyone know where I can get a schrader valve cap for the LT1's???? I just disconnected my nitrous and I can't find anywhere that has the caps. Also...I can use the valve instead a valve stem to plug up the "schrader" valve as it is technically the same thing, correct?
Old 10-07-2007, 08:02 PM
daniel6718's Avatar
the cap wont hold the fuel pressure..you cazn get the stem to screw back into it from a tire...
Old 10-07-2007, 08:04 PM
blind527's Avatar
What do you mean? So I can just run a valve stem into the tube, and not cap it? A normal bicycle tire cap won't fit over the opening, it's too wide. I can't find my original cap that was on the schrader fitting, that's what I basically need. I wouldn't just cap it with a plastic cap w/o a schrader valve installed.
Old 10-07-2007, 08:46 PM
dhdenney's Avatar
I used something like this. Mine wasn't near this expensive but you get the idea.
http://store.summitracing.com/partde...5&autoview=sku
Old 10-07-2007, 08:48 PM
blind527's Avatar
So if I can find a -3AN fitting at a hardware store that should pop right on?
Old 10-07-2007, 09:06 PM
dhdenney's Avatar
You're not gonna find AN fittings at a hardware store.
Old 10-07-2007, 09:33 PM
daniel6718's Avatar
its -41n anyways....
but the little plastic cap...go to a junkyard and get one from one of MANY cars...find a gm car or truck and it should have one...gm dealer?
Old 10-07-2007, 09:40 PM
dhdenney's Avatar
It's 3 or 4 one. I can't remember. I thought it was 3. I guess you're right though. I was thinking about the other side of the solenoids.
Quick Reply: Where to get a schrader valve cap...
