Should i raise my car back up?
So, im at college and the car will be coming back with me next week ( been sitting for a few months ). Should i keep the car lowered and bring it here? Or raise it up and bring it? Cause the firestone i took it to said that the car cant be aligned since its dropped 1.8in. Its been aligned for free basically, so i figure if i raise it back up, the car should be in alignment. But, ofcourse i would be sacrificing this SICK stance.
What would you do?
What would you do?
well, in a way it is kinda broke, they cant align the car correctly because its so low, they dont know what degree the tires need to be at, so im worried about toe wear and that i'll have to replace the tires a LOT sooner than later because of un even wear.
Take it to an alignment shop and have them take out as much camber as possible. Negative camber up to about -1.0 degree won't wear tires too bad. The most important thing is to make sure the toe is set to zero. Toe kills tires way faster than camber.
If you can get the camber under 1 degree, with zero toe, you will be fine.
Sounds like you need to find an alignment shop that knows what they are doing. Try another place. Tell them the problems you had with the other place. Typically a business will do a better job trying to earn your business that way.
