WTF am I doing wrong-pilot bearing removal
I just wasted 2 hours trying to get this damn thing out, and it didn't budge at all. I have the removal tool, I tried it countless times and nothing. Is there a trick to this? I even pulled the flywheel off just in case it was holding it for some reason.
I can feel the lip behind the bearing with my finger, but the tool won't grab it hard enough to pull it out. The tool just keeps slipping right out.
Please help!
Please help!
If you've got the rental tool from Autozone, you've got to modify it a bit. Get a dremel and take a bit of material off the arms. If I remember correctly, the two arms won't enter the bore of the bearing in order to grab the other side the way it sits. Once you dremel it, the arms will slide in, you can open the arms and use the slide hammer to pull it out.
The one I have has two arms, with a bolt that spreads them apart once it is in the bearing. I can get the arms in, I can open the arms in the bearing, but it won't hold strong enough to pull it out.
The case it came in says it's a pilot bearing puller.
Now, just to eliminate the possibility of me being a complete moron, the piot bearing does sit in the end of the crank, right? It guides the input shaft of the tranny when it's installed? I just want to make sure, this is the first time I'm doing this. Thanks guys!
I just re-read some stuff, so I know I'm working on the right friggin part.
Anyone else have some ideas?
I noticed that each arm on this tool has a lip at the end that is supposed to catch the back of the bearing. Well, it seems to me that they are a little bit rounded. How the hell is this thing supposed to grab anything being rounded!!!
Clean out the grease so its dry, and no dust or aything on the tool.
Like others said- Tool with sqare edges.
Tighten the tool up. so it spreading apart a bit, you can feel how far to flex the arm. But dont break them.
Don't move or wobble the slide hammer around once, the arms are tight. That will bend them, and mess up the grip. 2 people even hold it dead strait using it.
Try pop it out one hit. Every hit you lose a little of the grip. When the arms have a good grip,and the force goes into the bearing. And notjust bending the arms,or popping off. The little bearing popsout pretty easy. So you dont have to do a full hardest body thow into the slide hammer. But dont be a ***** with it, and do little Happy Gillmor tappy tappy 27 taps. That will not hold.
If you have been trying it already, see how the arms are fitting. And its there marks on the backside of the bearing, try to fine a "new" spot to tighten the arms.
If it dosn't work and you messed up the bearing or the tool. You can grind though the beraing, and colaps it Very cafully!
Dont try to use the pump grease ( wet towls, bread or whatever)into the back of the crank pocket, and force the bearing out. there a freeze plug in the end of the crank you'll just push into the motor.
I am so frustrated right now, I am really hating this damn tool. It's not the slide hammer type. It has a nut that pulls the arms back out as you tighten it. I grinded down the lips on the arms to make sure they were 90 degree angles, and it helped a little bit. I can feel it grabbing, but it doesn'e have enough holding power to get this thing out. I tried heating it up, still didn't help.
I'm working with limited tools, but this can't be this difficult when you have the actual tool designed to do it. Should I spray some WD40 on this thing in hopes that it will loosen up the hold?
Go and get the slide hammer type. Make sure you tighten the removal tool up pretty good and let it happen with the slide hammer. It'll come out after a few tries. Don't get worried if you rip apart the old bearing it will come out. And of course if all else fails get a small drimel tool and take away some of the bearing but make sure you don't cut into the crank!!!!! Thats how i've done many of them so best of luck.
ive done them several times by packing wheel bearing grease in it then putting the lineup tool in it and hit it with a hammer. it will take a while to get it packed might have to do it several times but it works
Well, it finally came out. The arms on the tool weren't holding enough to pull it out. So, we put an allen wrench in between the arms to hold them from flexing. First try like that, and it popped right out.
Now I'm just struggling getting the tranny lined up to go back in. Not to mention the tranny fluid all over the garage floor (yeah I tried to not empty it first!). Live and learn, but I think this is the last time I do any relatively major jobs on my own. Just not worth the time.
