4l60E car won't move
I put a 05 5.3 motor and 05 trann 4l60e in my '76 nova with a painless harness. Car starts and runs fine. But when i put it in gear it wont move it just sits there and free revs. Check fluid level seems fine every thing is bolted up and pluged in. Just not sure what to do. Does it need a tune or something? Please any help would be great Thanks.
Pull the bottom cooler line off and run it, seeif there is fluid coming out. If you were to unplug all of the elctronics it would still achieve 3rd and reverse.
I suspect your pump has failed due to the converter being improperly installed.
g
g
won't move
any gear i shift it in won't move does even jerk or anything when you put it in gear. Tried to pull off hose there was fluid in it but when i ran it for a few seconds no fluid came out do i have to have it in gear or fluid is always constant? Thanks again for the help
