Drag Racing Tech
running out of steam at the top of first
Old 10-15-2007, 09:54 AM
dlove's Avatar
Default running out of steam at the top of first
the car is a 00 z28 with about 109k miles
in first gear and only first gear the car just runs out of power and quits pulling around 5k. If i stay in it, it will slowly pull higher rpms. Once i shift to the next gear, it pulls hard again and keeps pulling all the way past 6k.
I thought my 4l60e was giving me issues so I pulled it out and sold it. Built a TH400 and put it in. The problem is still there.
I did a fuel pressure test and at idle it's 60lbs. Driving in 1st and all other gears it's 60lbs and does not drop.
Any other thoughts on what is causing this issue?
clifs- the car quits pulling at the top of first, but does not do it in any other gear.
Old 10-15-2007, 02:41 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
That's pretty weird, it is pulling a bunch of timing?
Old 10-15-2007, 03:50 PM
dlove's Avatar
that would be one of my thoughts that im going to check with a laptop. But then my question is what is causing it to not only pull timing but only pull timing in first.
Old 10-17-2007, 09:27 AM
dlove's Avatar
update- wideband in the passenger side pipe says 13 to 1 when WOT and does not change
I then pulled some codes and found a rich bank 1.
