My Art Carr 3600/3800 Nitrous stall sucks on motor!
Car wont even spin the tires for ****! I would like to get a Neil Chance but can't afford one yet. What do you recommend I do other than spraying it? It doesnt hit hard on motor. I had 1.9 60fts on 28/10.3wide/17 drag radials.
Cheap Options fellas?
I have a loose Art Carr stall, around 5000-5100. It is a MONSTER N/A. I would recommend them to anyone. I wouldn't even think about spraying it though, it's not designed for a hit. I also have a locally made nitrous converter that stalls N/A around 4000. The Art Carr out E.T.'s my nitrous converter (when N/A) by around .3 in the 1/8th or about .45ish in the quarter. Sounds like you want the best of both worlds in a stall, loose for an N/A run, and tight for a nitrous pass. Maybe spraying a 150 shot you could get away with it, but not a 300 shot.
You should give them a call to have them help you understand the reason they built your converter tight.
In a nutshell though... the converter needs to be tight for your 300 shot. If it was not you would most likely blow through it.
g
g
So.... does Fuddle or PI (Vigilante) or Neil Chance build a convertor that can stall to 4k on motor and handle a 300 shot...... basically a bit looser N/A yet handle the 300?? I have not sprayed the Art Carr yet...... still working to tie up loose ends with the nitrous system.
